hi chaps/chapesses
I ve installed SVCD2DVD (love his conversions quality) this worked for a few months, till i upgraded to 2.5. now all i get is FFMPEG failures all the time. i've down graded this software, reinstalled my O/S done everything i can think of and still the same 'FFMPEG' failure..... can anybody help....... please
Results 1 to 27 of 27
Which version of S2D (full version # 2.5.###)?
Can you open one of the assets that generates the error in Gspot and post a screen shot of the result?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
And can you post your log file of such a run?
Firstly thank you all for replying to my post.
I have reinstalled my OS (needed it anyway), reinstalled SVCD2DVD ver 2.5.3100. and i keep getting the same error.. I will display the failed log below. I am sure someone else must have had the same problem.
I never had this problem with the older versions, but can't get them on the web site anymore.... can anyone help or just point me in the right direction.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.3100.0
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2707539
Executable CreationTime: 16/08/2007 16:41:48
Executable LastWriteTime: 12/09/2007 05:19:41
Executable LastAccessTime: 20/09/2007 04:02:20
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 511 MB
Free Physical Memory: 165 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: ECS
Computer Model: M848A
System Type: X86-based PC
Computer Name: HOME
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: HOME\Cathal
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 2400+
Description: x86 Family 6 Model 8 Stepping 1
CPU Speed: 2GHz
CPU FSB: 133MHz
L2 Cache Size: 256 bytes
***************************** Time Zone ****************************
Time Zone: (GMT-08:00) Pacific Time (US & Canada)
****************************** VIDEO *******************************
Name: S3 Graphics Inc. Savage4
Processor: S3 Savage4
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 8.00 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 106 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="19/09/2007 21:02:23" Filename="NONE"><AssetSet><Asset ID="227f4b6e-944f-4c1e-8110-6176118a8e82" Path="C:\Documents and Settings\Cathal\My Documents\Downloads\XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX" Filename="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.avi" AssetID="227f4b6e-944f-4c1e-8110-6176118a8e82" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 700 MB
file=C:\\Documents and Settings\\Cathal\\My Documents\\Downloads\\XXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXavi
FormatName=avi
Num_Frames=163072
DurationInSecs=6801
Duration=01:53:21.5
VideoCodec=mpeg4
VideoFFSTNum=0
Width=664
Height=274
Standard=NTSC (Film)
BitRate=864
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=112
Audio1Channels=2
AVI2MPG: 9000kbs Full-D1
21:02:23: Looking for AVI PAR...
Pass 1/1: Processing XXXXXXXXXXXXXXXXXXXXXXXXXXXXX.avi
21:02:26: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
21:02:26: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
21:02:26: libavutil version: 49.1.0
21:02:26: libavcodec version: 51.27.0
21:02:26: libavformat version: 51.12.1
21:02:26: built on Jul 10 2007 10:38:54, gcc: 4.3.0 20061204 (experimental)
21:02:26: Input #0, avi, from 'C:\Documents and Settings\Cathal\My Documents\Downloads\XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXX.avi':
21:02:26: Duration: 01:53:21.5, start: 0.000000, bitrate: 864 kb/s
21:02:26: Stream #0.0: Video: mpeg4, yuv420p, 664x274, 23.98 fps(r)
21:02:26: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 112 kb/s
21:02:26: Output #0, dvd, to 'C:\Documents and Settings\Cathal\My Documents\Downloads\XXXXXXXXXXXXXXXXXXXXXXX.mpg':
21:02:26: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 9000 kb/s, 23.98 fps(c)
21:02:26: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
21:02:26: Stream mapping:
21:02:26: Stream #0.0 -> #0.0
21:02:26: Stream #0.1 -> #0.1
21:02:26: Press [q] to stop encoding
21:07:59: AVI2MPG: done.
21:07:59: Done: Processing assets for DVD creation
Authoring DVD Folders
21:07:59: Creating TitleSet # 1
21:07:59: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
21:07:59: -->: DVDFolders creating VTS
21:07:59: -->: VTS 01
21:07:59:
DVD Folders: Processing C:\Program Files\BadgerIT\SVCD2DVD v2.5\dummymenuNTSC.mpg...
21:08:00:
DVD Folders: Processing C:\Documents and Settings\Cathal\My Documents\Downloads\XXXXXXXXXXXXXXXXXXXXXXXX_S2D.m pg...
You are in breach of the forum rules and are being issued with a formal warning.
VideoHelp is not the place to get help with your illegal downloads.
Read the rules again.
/ Moderator mats.hogberg -
I am having the same/similar problem suddenly. I tried three times to create a DVD unattended and each time came back to a partial VOB file that would not play. A 4th time I was sitting at the machine when a window error box "ffmpeg.exe has caused and error and will be closed" popped up and disappeared. This was on a W2K machine that I have made many good dvds with your program. Today a I ran it a 5th time on another machine (XP64). This time it created a complete VOB1 and started on VOB2, but both were still borked. The log file is from the 5th run. There are about 10K buffer errors.Originally Posted by ChrissyBoy
Thanks!
TPM
svcd2dvdlog-20070921120549.rar
thepicman: You have a different issue.... the mpeg is not be reencoded. I will do a build for you to test to see if the problem is resolved as soon as I can.
thepicman: Can you test that file with the latest build to see if this issue is resolved please?
Will do CB. Later tonight, Its 9:40AM here, so I must off to work
Pretty much the same results. Logfile attachedOriginally Posted by ChrissyBoy
svcd2dvdlog-20070925205853.rar -
Indeed - i meant, can you download the latest build and retry? That log is 2.5.3200 latest is 2.5.3300...
Understood the 1st time. I did go to the registered site and d/l the newest version. Perhaps I reinstalled the older version. I'll check.Originally Posted by ChrissyBoy
Sorry - let me know how you get on...
No sorry needed. I was bummed at wasting your time. I was doing 10 things at once and was perhaps too far into the grape.Originally Posted by ChrissyBoy
Yes, in fact I did re-install .32.
stoopid me.
After installing the proper build, it seems to have run correctly and rather quickly. I am looking at the folder from a remote, so when I get in, I will test more fully. One bit of info that I did not notice from before was that .32 was showing my 5G asset (in the color coded file size bar) as over 6G and then making a 1G _SD2.mpg file. With v.33 it shows the same asset as just a skosh over 3G and makes a similarly sized _SD2.mpg file.
Hopefully that made sense. I'll report back after I have beaten the vob files with a stick.
TPM -
ok - sounding good. I await your results!
The VOBs play fine, audio is in sync. Have not burned them yet, but all seems well. Thanks!Originally Posted by ChrissyBoy
logfile attached in case you want to examine. Its quite a bit smaller than before, no buffer errors.
-TPM
svcd2dvdlog-20070926200356.txt -
Weird, the video in the VOBs is 4:3 and the interlacing is very evident.Originally Posted by ChrissyBoy
edit: the video in the _SD2.mpg file is 4:3 also, did I miss a new setting somewhere? The menu on the DVD is 16:9
-TPM -
Can you use the makesample tool in the SVCD2DVD\Tools folder to make a decent sample of your mpeg and upload it to ftp://uploader:badgers@nassau.globat.com/ for me to investigate please?
In the meantime - if you use the "Force 16:9" setting in the Video Encoding options you should be ok.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
2 13MB files in folder ThePicManOriginally Posted by ChrissyBoy
one is original one is SD2 mpeg -
Thanks - I will take a look in the morning.
Just FYI, I am away until Sunday, so I won't respond until after that.Originally Posted by ChrissyBoy
ok
Not really - but i never had a source of those dimensions to test with. Anyway I have fixed this for the next build. Do you want to test that (drop me an email)? Also did the force 16:9 wok for you?
Email sent, thanks!Originally Posted by ChrissyBoy
I did not test the 16:9 force as I was gone for a few days. I will try to force it later today, but I am leaving town again for Petit LeMans tonight and am not sure if I can in the time available.
Thanks!
TPM -
new build seems to be working like a champ. Redid original problem file and burned dvd. Am doing a new file with same specs and will report back.Originally Posted by ChrissyBoy
Thanks!
-TPM
Can a newer verson of FFMPEG be used with SVCD2DVD
By RJRobb in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Jan 2014, 07:15 -
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
svcd2dvd ffmpeg has stopped working adding dvr-ms
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 09:00 -
FFMPEG Stream mapping options result in conversion failure
By JackJack in forum Video ConversionReplies: 6Last Post: 27th Jun 2008, 23:19 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
