So I'm having a problem encoding from MPEG4 codec to .DV ....I get this:
[dvvideo @009B29C0]Can't process DV frame #THEN A NUMBER. Insufficient audio data or severe sync problem.
It keeps doing that for every frame. I'm using -target ntsc-dv ...
Converting a DV/DVCPRO AVI converts into DV no problem...when I convert the MPEG4 AVI it gives me that rolling error message but it completes it...it actually converts it but there is a severe sync problem!
Any idea how to fix it? The source video is MPEG4 AVI yuv420p 640x480 29.97 audio is adpcm_ima_wav 44100 mono
It is outputting by default to to dvvideo codec yuv411p 720X480 pcm_s16le,48000 stereo
Any ideas?
Results 1 to 1 of 1
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
IMTOO ripping prob
By sealclubber666 in forum DVD RippingReplies: 3Last Post: 20th Sep 2007, 13:05 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33
