    Aug 2007
    I had a home movie (2hrs)VHS which I made into a DVD on my VHS,DVD player. I want to take it into Mac imovie or idvd and add music, very old movie 50s no sound. The DVD is in two parts Video_RM and Video_TS. Some how I was able with ffmpegX to get it into imovie but not able to burn a DVD or save over to another HD. It took over an hour to copy the first time. I was not sure which settings to use so I winged it. Is there an easy way to do this??? What am I doing wrong.
    thanks for any help
    Vicki
    USA
    Probably better asked and answered in our Mac Forum. Moving You.
    And welcome to our forums.
    Aug 2007
    I may have put in to much info, just want to know at this time how I can save what I have from imovie or what I did wrong.
  4. Member terryj's Avatar
    N35°25.24068, W097°34.204
    First, get a copy of MPegStreamclip.
    Second get a copy of Quicktime-MPeg2 Component.
    Third, finalize the disc in your DVD Recorder
    ( you said Player, I assume recorder)
    Fourth, Open MPegStreamclip, open the VIDEO_TS folder
    on the disc, and open the first .VOB file.
    When prompted, click "open all streams".
    Fifth, with the file open, Fix all Time Code Breaks.
    Sixth, export the open file as .DV stream from Mpegstreamclip.
    Seventh, open the .dv stream file in iMovie.
    edit to your heart's content, then export out to iDVD or
    whatever you use to burn DVDs ( Toast?).
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Aug 2007
    Thank you soooo much
    I will try this. One thing, getting "Quicktime-MPeg2 Component " I only have Quicktime reader do I need more than this to buy Quicktime-MPeg2???
    It would be great to spice up this video for my Dad and Mom.
    Aug 2005
    Palo Alto, California USA
    You only need money. Go to Apple's website to buy the MPEG2 component. It's about $20, if I remember correctly.
    Aug 2007
    Bellingham, WA. USA
    @ Tomlee59:
    you could also use "Yade X" to extract all or just specific scenes from your DVD. You would first have to rip the DVD via "MacTheRipper". The order of the extraction/conversion process would look like this:
    -rip dvd via mactheripper
    -extract specific scenes or entire .vob files with Yade X
    -convert your extracted .vob files to whatev with ffmpegx
    -edit via QuickTime Pro or iMovie
    -Burn via iDvd
    Good luck with your project. Oh, Mactheripper and Yade X are freeware, and can be located via versiontracker.com or macupdate.com
    jigzila
    Aug 2007
    Thank you for the info. I need to try these options soon, work has been getting in the way.
    Not much luck with the first try still could not get the VOB file into Streamclip. Well did load just not right.
    Anyway Thanks
    I will try this
    Vicki
