  1. I have couple files, that when i open the file, AR is not (or does not seem to be) right. With one file, if i change video renderer from default to WMR7, AR is correct, when i open the file.
    I also got one file, that i'm not sure which AR is correct. Other AR doesn't look too streched and other not too shrinked. I mean with default renderer picture is bigger (more streched) and with WMR7 smaller. I can't for sure say which one is correct.
    How can i be sure that right AR is always displayed?
    Does this look correct AR? (I can't take a screenshot with WMR7 renderer.)
    http://xs218.xs.to/xs218/07345/bscap0000.jpg
    what do you play with? mpc? and what kind of files? avis?
  3. I use BSPlayer, but tried with MPC also. Yes, avis.
