    Mar 2007
    hi
    I have recently converted some old VHS tapes to DVD. Capture, edit, burn seemed to go ok with the final DVD-R running OK on my Pioneer Home cinema system.
    However, i am getting disk error when i try to run it on my older toshiba DVD player.
    I have authored using both Sony DVD Architect and ULEAD DVD movie factory 6
    what is the likely cause of this?
    I am thinking of creating an .iso and burn using another burning package?
    help apppreciated
  2. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    There is no set answer...
    1. IMGburn is popular (and good) for burning ISOs.
    2. Always use quality media like Taiyo Yuden or Verbatim.
    3. Some players (especially older ones) don't like recordable media.
    May 2003
    Peterborough, England
    If I remember correctly, some of the early Toshiba DVD players would only accept DVD+R. Some would not accept recordable at all.
    Apr 2004
    Miskatonic U
    Imgburn isn't restricted to ISOs - it will happily burn DVD Video from the Video_TS folder, and will also burn any files as data.
    Read my blog here.
    Mar 2007
    thanks for the replies, I'll give imgburn a go.
    Also, i get exactly the same problem with DVD+R and DVD
    +R/W
    I'll report back.....
