how would I integrate an mp3 song to an mpg file of the same song so it can sound good?
Im finding some mpg music videos with crappy sound and I was wondering if that can be improved by joining or integrating the mp3 song of the video file to the mpg file.
Well it doesnt have to be an MP3 file only. I wouldnt mind converting it to a format that will make the music video have much better sound which is the only goal that I have.
What is the highest quality source audio file that can get a hold of?
and
How are you planning to play the final file--hardware?, software?
Let's say you have a PCM master audio track, and you expect to merge with an existing MPEG2 video file and play on a settop player.
Well, excepting the OBVIOUS possibility of going to standard, compliant authored DVD, you could convert the PCM (and BTW, you must use something else as PCM won't mux into MPEG except in the special case of authored DVD-Video) into MP2, MP3, AC3, DTS, AAC. These should all be muxable into MPEG2 (I have succeeded before), so it's just a matter of choice of which encode and decode software you've got and the relative bit-efficiency of those codecs.
IMHO, they would go in the order I just mentioned (with the least "efficient" quality on the leftmost and the most "efficient" quality on the rightmost)
My guess is that you don't have an original PCM, so you want to go with something commonly available as a replacement. MP3 could do that (as long as you understand that it isn't compliant with DVD or VCD standards--though it is with DivX).
***BIG POINT HERE***
If you've got an MP2, converting it to MP3 or AC3 or whatever will probably do more damage to the quality of the signal than any improvement in the bitrate-efficiency. If that is the case, it's best to leave well enough alone...
AFA muxing, TMPGEnc will work fine with muxing those codecs mentioned above into MPEG2 (so will Imago, BBMPEG and a few others).
edit: you also want to make sure you use something that will be playable on the target devices (should be obvious, but you may need to do some testing first to know for sure).
MPG converstion to MPEG TS movie does not look and sound good
By tsaraf in forum Video ConversionReplies: 6Last Post: 26th Jan 2011, 09:20 -
Convertind sound from a music DVD to MP3
By avz10 in forum AudioReplies: 16Last Post: 11th Oct 2008, 01:54 -
Looking for some good instrumental music that would be good for football.
By ingeborgdot in forum AudioReplies: 8Last Post: 26th Nov 2007, 22:18 -
Why New Music Doesn't Sound As Good As It Did
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 12th Jul 2007, 18:44
