I've been at this problem for hours now and could use some advise. I got an 720p mkv file with a DTS stream that I try to play using DTS passthrough. The video plays fine (using mplayer on my Linux HTPC), but there are constant clicks/pops in the audio that make make it basically impossible to watch/listen. The receiver correctly identifies the stream as DTS and sound is good apart from those clicks. I've tried to analyze it with midentify, but so far I can only see that other files that do play correctly are apparently encoded using a52 while this particular file is encoded with ffdts.
This is the midentify output for the file:
This is for a file that does play nicely:Code:ID_DEMUXER=mkv ID_VIDEO_FORMAT=avc1 ID_VIDEO_BITRATE=0 ID_VIDEO_WIDTH=1280 ID_VIDEO_HEIGHT=688 ID_VIDEO_FPS=23.976 ID_VIDEO_ASPECT=1.8605 ID_AUDIO_FORMAT=8193 ID_AUDIO_BITRATE=0 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=6 ID_LENGTH=6354.32 ID_VIDEO_CODEC=ffh264 ID_AUDIO_BITRATE=128000 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 ID_AUDIO_CODEC=ffdts
Any pointers on how to fix this or what causes it would be greatly appreciated!Code:ID_DEMUXER=mkv ID_VIDEO_FORMAT=mpg2 ID_VIDEO_BITRATE=0 ID_VIDEO_WIDTH=1920 ID_VIDEO_HEIGHT=1088 ID_VIDEO_FPS=23.976 ID_VIDEO_ASPECT=1.7776 ID_AUDIO_FORMAT=8192 ID_AUDIO_BITRATE=0 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=6 ID_LENGTH=4203.92 ID_VIDEO_CODEC=mpeg12 ID_AUDIO_BITRATE=384000 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 ID_AUDIO_CODEC=a52
Results 1 to 1 of 1
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 11:50 -
DTS Stream for MKV's
By Flash2075 in forum Blu-ray RippingReplies: 5Last Post: 13th Feb 2010, 23:40 -
Converted mkv file can't keep DTS audio
By thegrube in forum Video ConversionReplies: 4Last Post: 11th May 2009, 15:49 -
How to remove DTS stream for .TS file?
By vertical in forum Newbie / General discussionsReplies: 15Last Post: 23rd Oct 2007, 20:39
