I need a new alternative to my current two x264 GUIs, Staxrip and meGUI. Staxrip has a bug where, if the bitrate you have specified will yield a compression deemed by Staxrip to be too low (like, say, 89% of the original quality), it'll forcefully decrease the bitrate against my wishes.
meGUI has been given me a major headache these past two weeks (problems documented here).
So I need an alternative to them.
Requirements:
* Has to be an x264 GUI
* Has to be able to produce iPod-compatible MP4/x264/2-pass files (so SUPER's out of the question)
* Preferably allows me to set the resolution myself
* Has to have manual cropping abilities
* Must produce files that don't intertwine (or whatever it's called) the audio and the video, allow me to mux and demux to my heart's content (as I use BeLight to encode the audio)
Suggestions?
Try DVD-Fab Video Downloader and rip Netflix video! Or Try DVD-Fab and copy Blu-rays! or rip iTunes movies!
Results 1 to 14 of 14
Originally Posted by celtic_druid
Or could you maybe just solve my weird meGUI problem? -
Hi
You could try this: https://forum.videohelp.com/topic331773.html
Or alternatively WinFF, there are iPod presets at the forum there for restoration so you can handle the Audio and video separately and mux them with NicMp4Box or YAMB with NicMp4Box substituted for MP4Box. I use this method for restoring video to H.264 all the time. If you want 2-pass with WinFF just enter "-pass 1" in the additional options field and then "-pass 2" and overwrite your first pass.My Site: http://www.bandshed.net/AVLinux.html
My Guide: https://forum.videohelp.com/topic330839.html -
OK,
Yes they are both GUIs and YAMB is a GUI for Mp4Box, they are all using the same x264 encoder, The encoder is only as good as the settings you feed it. I used to use MeGUI all the time, great little prog! I had a bit of fun improving the 3GP converter and WinFF will pretty much convert anything to anything. You know you could have at least checked out the links before posting back and asking if they were GUI's or not!My Site: http://www.bandshed.net/AVLinux.html
OK,
This will do what you want:
Download WinFF 0.291 :http://biggmatt.com/winff/downloads/winff-version-0.291.html
Download these presets:http://biggmatt.com/winff-forums/index.php?topic=29.0
Download PreMade YAMB with NicMp4Box:
http://www.bestsharing.com/files/kt74tJ325564/Yamb-1.zip.html
1. Demux (separate Audio and Video) your source file
2. Encode Video to H.264 with above preset in WinFF
3. Encode Audio with your choice to .m4a
4. Open YAMB to "mux" tab
5. Add your individual converted Video and Audio files
6. Mux and sync to iPodMy Site: http://www.bandshed.net/AVLinux.html
Hi
Well it just so happens that version 0.3 has just been released and
it has an option for 2-Pass, I would have linked you to it before but it was just posted on the WinFF web site about an hour ago. You are probably sick of downloads but the latest version is greatly improved. the 2-pass is in the "options" button. the quality is pretty good with 1-pass though but suit yourself.My Site: http://www.bandshed.net/AVLinux.html
When trying x264 i also tried:
AutoMKV:
http://forum.doom9.org/showthread.php?p=854221#post854221
MEncoder264
http://forum.doom9.org/showthread.php?p=802244#post802244
RipBot264
http://forum.doom9.org/showthread.php?p=1021081#post1021081I love it when a plan comes together! -
Here's something real sweet, and FREE: HandBrake.
Limited input though - only DvD source, MPEG-2, and TS, but still fabulous and almost everything you asked for in your first post (except uses FAAC for audio).
Although the defaults are for QuickTime compatibility, you can still configure any x264 settings you wish.
Oh, yeah - does iPod too.I hate VHS. I always did. -
Originally Posted by FallenAngelII
It is the same x264 Encoder (maybe not the exact version number) it is just incorporated into ffmpeg. How good or poor the results are depends on the settings used, I don't know what you were using for settings in MeGUI, I have written the presets with as many quality tweaks as I can get away with and be iPod compliant. You will have to try an encode and let your eyes be the judge.My Site: http://www.bandshed.net/AVLinux.html
Change subtitles names in MultiAVCHD so that these names appear on tv
By Delta007bhd in forum SubtitleReplies: 0Last Post: 20th Sep 2011, 12:53 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:31 -
x264: -1920, -ESiR, -SEPTiC, -CiNEFiLE.... What are these x264 extentions?
By NWNewell in forum Newbie / General discussionsReplies: 7Last Post: 18th May 2009, 17:10 -
x264 encoder from x264.nl or videolan.org?
By StephanP in forum Video ConversionReplies: 1Last Post: 4th Feb 2009, 14:38
