Well I gotta a copy from an original DVD-9 movie in ISO form (5.4GB), i wanna burn the movie but all i have is 4.7GB DVD-R blanks, is there any possible solution, or should i re-author the movie or what?
Try DVD Shrink. It accepts DVD's in ISO format. Then you can shrink it down to fit a DVD-5
I want all the menus and extra material,I can't remove anything(Full Disc), so i have to recompress is DVD-Shrink able to do it, as you can see my computer is not the right machine for this stuff, i'm afraid of a Sync problem in the end of the process ,
Any suggestions? -
I would still suggest Shrink. It will preserve all that, at the expense of some quality loss. You shouldn't have any problems with sync. Even with a slow computer, it will still be much faster and easier than most of the alternatives.
If you want a little better quality, try DVD Rebuilder. But it may take a long time with your computer. As you don't have to 'shrink' it that much, I would try DVD Shrink, though. -
I don't care about the quality loss, I'll try Shrink,
and I appreciate your help Sir, that was incredibly kind of your part,
regards ;D
Trying to convert for DVD burn-age...
By Follow_The_Day in forum Newbie / General discussionsReplies: 13Last Post: 4th Nov 2010, 23:01 -
Any program that can convert VIDEO TS to dvd and burn?
By Takeonelastbreath in forum Newbie / General discussionsReplies: 16Last Post: 22nd Sep 2010, 19:25 -
Convert AVI and burn to DVD: problem w/ NERO
By jimbo213 in forum Video ConversionReplies: 3Last Post: 3rd Aug 2009, 04:10 -
cant burn to +rw in convert x to dvd
By crashiam in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2008, 19:52 -
How to convert and burn .MVD into the DVD?
By coody in forum Video ConversionReplies: 1Last Post: 1st Oct 2008, 02:22
