Please don't hijack threads.
/Mats -
Mats,Originally Posted by mats.hogberg
I'm not sure what you mean. But I just noticed something strange. I was replying the tread "Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4". Don't know how it becomes a new tread. If that is what you mean by hijack, I apologize, but I don't know what happened. Hope that this post will not generate a new tread again.
Thanks,
Jean -
It became a new thread becase you hijacked a thread and a moderator split your post off to it's own thread.Originally Posted by Jean
Hijacking is taking over another thread with stuff not strongly related to the original topic. Either it's off topic or too far removed from relation. And so on.
I'm sure someone else can better define the term.
Your post is not related to video format.
It's for the most part an audio processing enquiry.
Interesting beast you have there.
What do you play it back with?
i'll assume a safe demux possible with something like avimux-gui.
Then,
why mp2? No reason not to go with ac3. Preferable.
Use avisynth with nicaudio to import dts audio with nicdtssource(),
and encode with aften to ac3 (or toolame for mp2).
Behappy is a nice frontend to simplify the process.
http://forum.doom9.org/showthread.php?p=757876
video as usual...
kill audio processing in mpeg2 encoder
gl -
Thank you for your explanation.Originally Posted by 45tripp
The reason why I need to convert to mp2 is that my favorate DVD author tool: TMPenc DVD author can't play AC3 audio. That is a good tool to edit DVD (such as adding chapter at right place). I don't know if there is better tool for that -- so I don't have 2nd choice in terms of audio format. -
so?Originally Posted by Jean
you're authoring not viewing.
Of course you have choice.Originally Posted by Jean
Of course there are better tools.
No need to change if you are comfortable.
gl -
What I mean is: If your post is not a reply to a post already in the thread - Start a new! This time, I split your post out, as a separate thread, as it AFAICS had very little to do with the posts in the thread you posted.Originally Posted by Jean
/Mats
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
how do i remove DTS from AVI, convert audio then remux..?
By snadge in forum Video ConversionReplies: 6Last Post: 3rd Dec 2009, 06:58 -
Convert divx avi with dts to ac3
By mk15 in forum AudioReplies: 3Last Post: 23rd Jun 2009, 03:46 -
How to convert DTS audio to AC3?
By Henderson in forum AudioReplies: 1Last Post: 26th Jul 2007, 17:33
