I'm in the market for a new laptop computer - and have my eye on a macbook pro...
I currently use my pc with ulead studio10.... but want to switch to doing that on the macbook.
My camera is an analog Sony TRV-66 - Hi-8 XR.
If I am correct - my options for importing movies into the mac would be:
1) Capture on the pc and transfer to mac via firewire 400 (um possible - but why?)
I'm not sure why - I've read that the data size is approx 13GB per hour - but mine have been about 1GB - quality on an old TV looks ok - I'm guessing it must be Mpeg that compresses it - vs an uncompressed avi format - which I'n not sure the avi would work well with mac ...)
2) External capture device for mac (suggestions appreciated here - even with the macs speed I would guess a dedicated encoder would remove overhead)
3) Perhaps - if the $ has to be spent for an external capture device - a new camcorder that can accept s-video (as well as composite) input - could then export/convert/encode the analog signal to something the mac could use via firewire.
So... what ideas/recommendations/views do you have?
I appreciate any and all ideas.
--ps - 1st posting - have read and gleaned much -- and refer those who have questions to check this site it - great site.--
Results 1 to 1 of 1
Recommend one good external capture device
By jranaudo in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2010, 03:35 -
External analogue capture device to stream to Livestream/uStream etc
By batfastad in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Jul 2009, 07:59 -
Pal-60 Compatible External Capture Device?
By Justin-NZ in forum Capturing and VCRReplies: 6Last Post: 22nd May 2008, 11:30 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Should I get a new camcorder or an external capture device?
By steppenwolf_27 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 9th Jul 2007, 15:36
