Previously for converting AVI's to DVD format, I'd use DIKO and then open the .mpv and .mpa files into DVD-Lab Pro and author the DVD using that. However this time I went to compile the DVD in DVD-Lab Pro and I got an error saying "Can't find AC3 audio frame header" so I'm assuming the audio is some how messed up. So I was going to try to extract the audio using something else, but I have no idea what would work well. Any suggestions? Also, what do you think might be causing the issue?
Also, this isn't related to my problem exactly, but I don't really like DIKO too much. So anyhing else you guys can recommend where I can input multiple AVI video files and get an output of .mpv and .mpa files that I can then load into DVD-lab Pro. Because I do really like using DVD-lab Pro, just not DIKO.
Thanks in advance!
EDIT - BTW, this is exactly what DVD-Lab shows me...
	Try this - it'll create a 5.1 upmixed AC3 out of the Mp3 track in your AVI file
 (note - install avisynth )
 https://forum.videohelp.com/topic326127.html
	Thanks, I'll give it a try. Hopefully it'll work. Unfortunately, I'm not even sure if that's the problem. I'm just assuming it is. Since it says there's an error after title 3, I'm assuming that there's a problem with the audio for that specific title. So I'll try that script for that video and see if it solves my problem.
  Extracting Just The Musical AudioBy niteghost in forum Authoring (VCD/SVCD)Replies: 9Last Post: 6th Jan 2011, 06:09
  Extracting audio from .tsBy leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 17:22
  Extracting Music from Audio CDBy prayami in forum AudioReplies: 4Last Post: 4th Aug 2008, 18:59
  extracting audio and changing itBy usermm in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2008, 15:41
  Extracting audio from avi - only does first 13minsBy DBIV in forum MacReplies: 5Last Post: 21st Jul 2007, 21:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
