ok i have had a long dat with this television
http://esupport.sony.com/US/perl/mod...l?mdl=KLV26HG2
and this laptop:
http://us.acer.com/acereuro/page4.do...41#inu57_39782
the laptop must be hooked via VGA and another connection on my television
1.i tried gold tipped S-video -> S-video and the quality was horrible so i returned the cable telling them
2. i bought a vga connector cable with a dvi converter at the end of one side and found out that you cannot have vga to dvi because vga is analog and dvi is digital so i returned that
3. i just went and got a vga to rca component cable similar to this:
http://www.cablesnmor.com/vga-rca-cable.html
and it does not work either! the screen turns purpleish
i have tried everything i dont know what else to do, any suggestions?
thank you!!!
Your sony and acer links don't work.
If there's no DVI output on your laptop, and no VGA input on your TV, you may be stuck with s-video.
COnnecting Sony Vaio Laptop to Pioneer TV with VGA/RGB cables
By togu68 in forum Media Center PC / MediaCentersReplies: 2Last Post: 25th Aug 2009, 21:47 -
help with laptop-to-LCD - VGA-to-RGB
By snadge in forum Media Center PC / MediaCentersReplies: 32Last Post: 10th Jul 2009, 12:19 -
Problem in connecting laptop to Sony LCD TV (KDL-52XBR3)
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2007, 14:31 -
Issues while connecting IBM T42P laptop with Sony 46" XBR3 lcd tv
By nikulb in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2007, 18:52 -
Laptop vga out to LCD tv (not a "no signal" problem)
By Keystr0ke in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 12:15
