  1. I have a Sony Home Theatre in a Box. The receiver has one coaxial audio in and one optical toslink in.
    Can I only choose one or the other? Or can I hook up two different devices to each one?
    e.g. I want to hook up a DVD Recorder to Coaxial and I want to hook up HDD Recorder to Optical
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    yes - but of course you can only use one source at a time - but they can stay connected at the same time. I did that when I had a xbox 1 - the dvd player was coax and the xbox was fiber optic. I'm planning on doing that again with my used ps2 I got earlier in the year. I just still haven't gotten around to hooking up the cable.
  3. yeah, i plan on havin one off while the other is on... so i'm kool with stikin stuff into both inputs?
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Yep. Plug away
    Your other option is you can get a fiber optic switcher. You can get it where you can have multiple inputs into just one jack. THen you just switch which unit is active. I haven't seen one myself but I know they have to make them. THat way if you have a ps2, ps3, xbox 1 or 360 and all are fiber optic only then you can plug them in and switch at will.
