I have Real Player and Classic Player that plays fine on my primary monitor. As soon as I drag the player onto the secondary monitor, the video screen goes black. If I drag the playing video half on the secondary monitor and half on the primary monitor, the primary monitor shows up fine and the secondary half of the video is black. Same if I expand it to full screen on the secondary monitor. I'm running this on Win2k and using a Benq FP567s LCS screen. The hardware acceleration is Full and turning it down does not solve the problem. WMV video plays fine on the secondary monitor using other video players. The problem is just with Real Player. I am using the latest Real Player.
Brent
What's your video chip? With my ATI and Catalyst drivers I can set 'Theater Mode' which allows overlay to appear on the secondary. If you're adjusting 'Acceleration' in Desktop -> Properties -> Settings you might try adjusting it in DXDiag instead. Just my two cents worth of things that have worked for me.
MPC won't display on secondary monitor
By Monarch1st in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 12:11 -
Black borders on monitor screen when connecting with HDMI
By sohaibrazzaq in forum ComputerReplies: 1Last Post: 27th Oct 2011, 22:35 -
How can I connect my HDTV to my computer as a secondary monitor?
By cucuzza in forum DVB / IPTVReplies: 6Last Post: 15th Feb 2011, 11:06 -
TV Tuner Display on Secondary monitor?
By wakarusensei in forum DVB / IPTVReplies: 4Last Post: 6th Dec 2008, 14:51 -
Nero Showtime shows black "screen" on secondary monitor.
By fk in forum Software PlayingReplies: 2Last Post: 12th Jul 2007, 15:06
