I record PAL SD with Hauppauge PVR150 and use ffdshow for playback to RGB connected interlaced TV.
I can set the TV out as single display in PAL resolution and interlaced 50Hz but I can not find a way to get a "no scaling, field sync" out that lets the TV do the deinterlacing so I would like ffdshow to do the deinterlacing.
I have a 3.0Ghz HT CPU.
My current FFDSHOW deinterlacing setting is set to ffmpeg deinterlacing, does not generate a high CPU load but there are still some motion artifacts (more then only halo's)
What deinterlacing setting would you recommend?
Results 1 to 1 of 1
The requested operation requires elevation. WHAT!?
By Hikari112 in forum ComputerReplies: 16Last Post: 2nd Feb 2018, 06:08 -
ripbot264 help requested.
By potprinc3 in forum Video ConversionReplies: 8Last Post: 20th Aug 2011, 09:48 -
Solution Advice requested. Copy several movies at once?
By ehcah in forum Newbie / General discussionsReplies: 10Last Post: 3rd Dec 2010, 21:31 -
Analysis requested....... my system setup
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 15:18 -
Suggestions for DVD cases requested
By pooty13901 in forum MediaReplies: 7Last Post: 1st Dec 2008, 14:42
