Most of the movies I want to convert to vcd format are in 352x240 res.
I have a 45 minute one I am working on currently at this resolution. Should I convert it to VCD or SVCD? My dvd player does both, which one will look less blocky?
If most of the movies are CURRENTLY at 352x240, then I would do VCD, because "typically" you never want to resize to higher resolution than your source....now if you are trying to obtain subtitles, & other SVCD features, then obviously you have to do SVCD.
I see,
so resizing to a higher resolution causes the blockiness, that makes sense.
thankyou
powerpoint conversion to VCD
By Kratz in forum Video ConversionReplies: 2Last Post: 19th Feb 2010, 15:16 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11
