Hi,
Can anyone help me with this DVD player? It is a 12/24Volt player that is being built into coaches and can be used in cars. The 06C is the new version over the DVP-01. The 01 version was stopped being built sometime in 2004/05 or 06.
I opened the player to see if there are any standard parts from other suppliers but that doesn't seem to be the case. The mainboard, the player-board and the 'key'-board all have the product number printed on.
This seems to be a completely customised product for Blaupunkt by some company in China. It is being sold in small quantaties, possibly only or mainly in Germany or Europe.
I am using this for a particular application and the player does not fully comply with the standard DVD specification. In order to find out if I can change its behavior I would like to be able to access the hidden menu.
Product:
Blaupunkt DVP-06C
Made in P.R.C
Mainboard:
BM-2
94V-0
E213371
DVP-06C MainBoard VER2.1
ASD 2006-09-07
85-RN-00010G
1.6MM
Cheers
Most car dvd players cannot be changed without a firmware change/update.
To access the "hidden menu" you often need factory remotes and/or tools.Google is your Friend -
Thank you Krispy Kritter,
That's bad news.
But it makes me think, what kind of DVD firmware hacks there are around - for any kind of DVD player and/or for my particular player!? -
DVD player "hacks" are just codes that unlock features/options controlled by the firmware. They are mostly found in players sould by manufacturers that use firmware among different models that are often sold in different countries. Some manufacturers, such as Sony and JVC, spend the extra time to lock the firmware to prevent such hacks from working. Players for automobiles fall into the same category as Sony and JVC. They are created for a specific use and locked to prevent tampering. At least I've never seen or read about a hack for any auto based player.
Your best bet would be to contact the manufacturer. If it can be corrected, it will likely be by a firmware update.Google is your Friend
Region Hack for Sony DVD DVP S360
By Lenfid in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st Dec 2011, 18:17 -
Sony DVP-SR150 Region Hack Required
By Fingers_Phil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 30th Jul 2011, 11:44 -
Sony DVD Recorder RDR-GX350 - Region Hack Code Required.
By Teac23 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Sep 2009, 03:19 -
Cambridge Audio DVD53RW DVD Player - Region Hack Code Required
By Teac23 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2008, 10:43 -
looking for regional hack for sony dvp ns415 dvd player
By case310350 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Aug 2007, 11:57
