Hi!
I have a problem regarding HD which is an h.264/MPEG-4 stream.
I've spent lots of days trying to find out an solution to make an 2-pass XviD encode (.avi format).
I'm hoping you guys might have an idea how to solve this.
Link for an 14MB HD stream to play with: http://rapidshare.com/files/50524437/SVT_HD.ts.html
Thanks.
Edit: I managed to get that file to xvid 2-pass, my problem is with bigger files (with more moves).
Link for a bigger file: http://rapidshare.com/files/50543434/20070703_2010_SVT_HD.TS.html
	You haven't qualified the problem at all.
 the goal, the problems, the tools?
 in anycase mencoder can do a 2 pass no problem,
 audio sync concerns me a bit, and there's a reported broken frame
 but:
 http://www.wikiupload.com/download_page.php?id=204381Code:mencoder hd.ts -o menHD.avi -ovc xvid -xvidencopts bitrate=6000:vhq=4:pass=1:turbo:max_key_interval=200 -oac mp3lame -lameopts cbr:br=128:mode=0 mencoder hd.ts -o menHD1.avi -ovc xvid -xvidencopts bitrate=6000:vhq=4:pass=2:max_key_interval=200 -oac mp3lame -lameopts cbr:br=128:mode=0
 Also for some more info/inspiration, I know soopafresh has got some scripts to deal with avc .ts in a thread somewhere.
 You could search for it.
 gl
	Thanks alot 45tripp, it acutally works
 I still have a problem though as source is 50 fps and i want to make it 25 fps without any blocks/hacks/slowdowns etc.
 I know it's possible but i can't get it to work.
 Any ideas?
	why?
 i don't have your sample to look at right now.
 start by reading this
 https://www.videohelp.com/forum/archive/hdtv-720p-50-fps-gt-sdtv-pal-576i-p-25fps-t333774.html
	same resolution?
 anyway
 did a quick one pass with mencoder
 looks fine to me
 http://www.wikiupload.com/download_page.php?id=209272
 Code:mencoder hd.ts -o menHD.avi -vf framestep=2 -ofps 25 -ovc xvid -xvidencopts bitrate=3000:vhq=4:max_key_interval=200 -oac mp3lame -lameopts cbr:br=128:mode=0
  advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-passBy codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11
  Technical Query Re Reading of 1st pass stats during second pass xvid encodeBy onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59
  Quick AVI Creator 1 pass xvid preset?By MilesAhead in forum Video ConversionReplies: 0Last Post: 17th May 2010, 17:25
  How Can I convert avi(xvid) to ipod tv out (H.264)?By felix in forum Video ConversionReplies: 8Last Post: 1st Sep 2008, 11:27
  Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subsBy Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
