    Sep 2006
    dos anyone know where i could buy Lightscribe dvdrs in packs of 50 or 100? or just realy cheep ones?
    thanks
    Feb 2007
    I've not checked but you could do worse than check UKDVDR in Edinburgh.
    Web site is www.ukdvdr.co.uk
    I did a quick search on kelkoo but that didn't turn up anything bigger than 25's so you may struggle
    Good luck tho'
  3. Banned
    Freedonia
    Almost nobody makes Lightscribe discs, so your options are limited. I'd advise buying Verbatim and not trying to save money. Verbatim makes high quality discs and if you buy a cheaper brand, you may find years later that your discs are bad and can't be read. It happens when you try to save money. Take a look at
    http://www.nomorecoasters.com
    for more info.
    May 2007
    France
    If you are based n Europe, Try ShoXX.com
    http://www.shoxx.com/catalog/product_info.php/cPath/3_127/products_id/1600?sID=
    Verbatim DVD +R 16X 10pack for 6,95
    Last week had a special offer and the same product was for 5,90
    Jul 2007
    Worldwide ;-)
    Hi!
    I must say that i agree with jman98 - that Verbatim is surely a way to go, and that trying to save few cents by buying some no-name brand media, can cost you 100 or 1000 times as much later if you find that your recorded data is corrupted due to cheaper but also worse quality media.
    Also, IKnowNothing was correct when he said Lightscribe (or Labelflash) media in pack over 25 are hard to find (if at all).
    Finally, let me confirm supradyn's statement about www.ShoXX.com online shop. It's managed by a really great and dedicated team! Let me share my expirience with them : Almost 2 years ago, when LabelFlash was introduced (and with NEC releasing 4551A labelflash burner), labelflash media was nowhere to be found. And since I bought that 4551A, I also wanted to check first-hand how that "new technology" works. So I urgently needed LabelFlash media and because i "found" Shoxx website even earlier, I decided to ask them about availability via their online form (cause they didnt have them listed yet). Next day i received a reply saying that media is already ordered and should be with them in 2-3 days, and so I asked them to send 10 5-packs (dont know if they still made them today or this 10pack from FujiFilm now replaced them?!) as soon as they arrive. And in less than a week they really came! I still remember how happy i was at that time...and how all friends wondered where i got them from, hahahaha...
    So...in case you cant find those 50 or 100 packs nowhere else...I would advice you to ask Shoxx team about them, cause i am sure they'll do their best to get them for you if only they exist in our galaxy. 8)
    Or try eBay? Or...? Well your choice to make...best wishes
