Hi,
I wonder it someone could recommend a software with nice transition for adobe premiere, have search and look but no luck, seems like pinnacle have more and cooler, what about the professional adobe, dont they have like that??
thanks so much
Premiere Elements has most of what you need at a good price. In the same market you could also consider Vegas Movie Studio or Ulead video Studio. All are better than Pinnacle.
Read my blog here.
You can do quite a lot with Premiere if you learn the tools.
For more transition effects check out Boris FX and Boris Red.
http://www.borisfx.com/product/fx/
For 2D animations that look like 3D + compositing features check out After Effects.
http://www.adobe.com/products/aftereffects/ -
you can use pinnacle hollywood fx with premiere pro .also u have adorage plugins for premiere pro.they have the best transitions
You might also want to consider the "gradient wipe" transition (wich comes with every version of Premiere, since the very first ones) Years ago there was an effects package named "Video Spice rack" (donīt know if itīs still made) and if you seek you can find packages of free gradients designed for that transition(even guides to create your own). There are hundreds of designs and some of them make really interesting effects (some are just too cheesy), you can customize them even more once youīve selected them and are very easy on Premiere CPU and memory wise (usually render really fast)
Adobe Premiere Transition help
By philler in forum EditingReplies: 0Last Post: 26th Oct 2011, 03:01 -
FREE transition plugins for Premiere pro cs3
By mudh in forum EditingReplies: 0Last Post: 14th Oct 2011, 17:00 -
[adobe premiere] how to add a transition, my curso is block when i drag !?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Jan 2011, 07:39 -
Transition problem in Premiere CS4
By yohan_nl in forum EditingReplies: 2Last Post: 25th Sep 2010, 13:16 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
