hello we've been shooting hunting video on a sony videocam and save the file on my hard drive as a .wmv. I've been trying to convert to xvid to try and clean it up but seem to make the piture worse is there a trick and better program. I'm using nero 7 ultra. and also tried alltoavi. With no luck to either one. Any help or suggestions would be appreciated
What format does the camcorder output? If it's DV over a FireWire connection, I would skip the WMV step as it seems unnecessary and will cause quality loss if you just plan to convert it a second time to Xvid. If you are using Windows Movie Maker for editing, output as DV instead, then encode that to Xvid.
Or do you mean it's a DVD camcorder? Then I would still skip the WMV step.
If I convert to Xvid, I use VirtualDub or VD Mod. It's also a editor and has quite a few filters available if you need them.
And this isn't authoring. Moving you to Newbie/General.
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
video cam = $39
By zoobie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Dec 2008, 16:14 -
Looking for pro video cam... need some help
By RockWood610 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Jan 2008, 22:41 -
Cam Video Tool 4 DVD Flick
By AleksandrIgnatov in forum Video ConversionReplies: 0Last Post: 2nd Jun 2007, 22:55
