Since a good number of people are using the MMC 7.5 for the ATI cards, it would be of great help to all of us if someone knew where we could get additional frames sizes for that AVI section of MMC 7.5.
Right now the choices are very limited and seem to focus on the Vertical resolution, which to me is not as important as the Horizontal res. If you want to capture at a Horizontal res of yyyX480, there is only one choice in MMC 7.5 and that is full res of 640x480. I want and need 480x480.
Since the performance of my system seems to be limited an can't quite make it to 640x480, and I really want to capture both frames (i.e. need 480 to do that), I'm stuck and so are a lot of other people.
I've tried using VirtualDub and setting custom res to 480x480, but it won't perform,... and I think it's because that res does not exist in MMC 7.5. I've also tried AVI_IO, and it's the same story,.. while you can set the custom res,... the capture produces frozen video and good audio. Again, these programs both depend on the ATI capture card for video in. If they try and set a frame size that doesn't exist,.. who knows what happens.
Any suggestions would be appreciated.
Results 1 to 1 of 1
"Technology",...It's what keeps us all moving forward.
Can't Find a Conversion from MP4 that SONY Digital Frame DPF-D830 Will Play
By pmconway in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2012, 03:11 -
Trying to find the DVD ripper with the biggest frame size
By True Colors in forum DVD RippingReplies: 2Last Post: 18th Apr 2010, 23:01 -
How to find out Frame Rate and Video Length
By GSReddy in forum ProgrammingReplies: 0Last Post: 20th May 2008, 01:02 -
Missing Codec(s) ... How to find/install/use?
By CaptainChaos in forum Video ConversionReplies: 7Last Post: 18th Oct 2007, 03:47 -
How to find the real codec - VLC plays but WMP wont
By oglasifwd in forum Software PlayingReplies: 1Last Post: 5th May 2007, 20:20
