i have never had a problem copy my old dvd's incase anything happened ot my originals. now when i put the original in the dvd player it won't even read or recogize anything in there, but will recognize one of the copy versions i had done about 4 months ago. this is not one 1 dvd this is one 3 of my older ones. all comedy classics. any help i have a lg dvd player/ burner and even powerdvd won't paly them
Open tray and blow some air into it , thats about the best you can do to clean the lens without pulling it apart .
If the unit is getting on , two years or older , it could be a sign of it wearing out depending on how much work it has done over the time you have owned it , but it might just be wanting the firmware updated to start off with .
Remember , this media dosent tolerate not being cared well for , and there are time's when all of us have suffered purchased dvd's which have decided to no longer work properly .
Isobuster might be worth investigating , but if they cant even be read by the unit , it wont help .
Place the dvd with the printed side upside down on a hard , flat surface , and use a soft lint free cloth , gently , and slowly clean from the center to the outer rim in a straight line , do this a couple of times , then try them again .
Might get them readable .
Copying a DVD
By grominnetto in forum Video ConversionReplies: 5Last Post: 17th May 2010, 20:31 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
Copying DVD's
By lsvtec in forum DVD RippingReplies: 2Last Post: 16th May 2008, 03:06 -
Re:Copying a dvd rw
By lol23 in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 05:54 -
Copying DVD
By carper in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2007, 09:41
