Hello,
I was wondering if it was possible to harness the power of multiple computers to encode a single DVD simultaneously?
My current CPU is a weak 3800+, so encoding a DVD can take upwards of 2 to 3 hours at times. I own 2 laptops and 2 desktop computers, so i was wondering, is it possible to use my other 3 computers to encode a DVD at the same time in order to cut down on encoding time?
I will be purchasing a new computer sometime within the next few months (with hopefully a dual or quad core CPU), but i was simply wondering if there was a way to help me in my current situation.
Thank you for your time.
Welcome Bacender
Well you can , but it also depends on what your source files are ... from the sound's of it , getting a faster system really isn't going to make that much difference in the time it takes .
You might use one to do the conversion , and another to create backgrounds for the menu (motion menu scripts and alike) , but that's about the max , unless you can split the source file up and let each system encode those parts ... finally merging them back on one system later and connecting the menu components at the same time .
I encode files across my lan on rare occasions , but have little need to do so . -
As can DVD Rebuilder - that's one powerful freeware app, plus has distributed encoding support via a plugin called RB Farm -
http://dvd-rb.dvd2go.org/modules.php?name=Downloads&d_op=viewdownloaddetails&lid=51&ttitle=RB_Farm -
DVD-RB does lend itself to distributed encoding because of the way it breaks down the disc by cell. I can't see why the plugin can't easily be modified to work with HCEnc as well.
That said, it is only useful if you already have a disc, but not much help if you are still at the authoring stage. Nice to know about though.Read my blog here.
Vidomi also has distributed encoding.. Free and easy to use..
http://www.vidomi.com
-Matthew
Playing MKV with multiple audio tracks - does it load computer more?
By tufffta in forum Software PlayingReplies: 6Last Post: 4th Mar 2012, 17:44 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
How can I use multiple usb video capture cards on one computer?
By gbenson in forum Capturing and VCRReplies: 0Last Post: 27th Jan 2011, 19:47 -
Encoding for Multiple Devices
By Scarpad in forum DVD RippingReplies: 3Last Post: 2nd Oct 2009, 13:43 -
Do you use multiple monitors on your computer?
By yoda313 in forum PollsReplies: 23Last Post: 1st Dec 2007, 12:00
