I just want to clarify things.
Can I assume that uhf is for more large scale projects that is there is a large or long distance between the transmitters and receivers? And Can I assume that if I go with vhf, it will mean that the transmitter and receiver has to be in close proximity?
Need some suggestions
	How's My English?
	Actually it is the opposite. VHF is usually used for greater distance. UHF needs more power or a more directional receiving antenna for the same distance.Originally Posted by wan2no
 What are you trying to do?
	i'm trying to really cut my budget.
 I've realised that the vhf products are alot cheaper than the uhf so i just wanted to know the benefits and drawbacks to it. I'm not looking to use the mics for concerts as yet. I'm more into using them with weddings and other small scale eventsHow's My English?
	Either will work. UHF has more available channels and less subject to interference in a city. There are lots of app notes online.Originally Posted by wan2no
  Hello I'm New & I Have A Question About DVD Shrink 3.2By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 05:28
  Pizza Box DTV Antenna (UHF only)By edDV in forum DVB / IPTVReplies: 30Last Post: 25th Jun 2009, 16:25
  Small ffmpeg & bitrate questionBy vvkeer in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2009, 09:30
  HD-DVD & BluRay questionBy likwid8 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2007, 18:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
