I have a mpeg4 that is uses divx as the codec. I have downloading the codec and it will play in WMP but it still won't import into an editing program. After messing with it for a couple days I've resorted to asking for help. I'm including a screenshot from Gspot for more info on the file. Any help would be greatly appreciated
	Welcome nagihcim1
 Take a good look ... anything stick out .
 Some programs might have an issue because of the file's extension being MPG and not AVI
 Try renaming the file ... remove mpg extension , replace with avi , then see what happens .
	I have used Super to get it to work but I didn't want to encode it using Super and then encode it again using the editing program. I changed the extension to avi and it will import just fine. Now I can kick myself the rest of the day for spending so much time on something so simple. Thanks guys.
	I didn't mean to encode this file using divx originally. That's why it's taken me so long to get around to converting it. I record most things in mpeg2 format and then edit and burn to dvd (or convert to mp4).
	As you mentioned earlier you didnt want to be recompressing files avoid recording to MPEG2 if you are going to then edit it. I dont know what sort of file sizes you record or what type of editing you do but recording to MPEG2 is not a good editing format either as it is already compressed.
 If you have the room record to AVI or DV AVI or a less lossy codec, then do all your editing and then export to MPEG2 for DVD or whatever your final format will be.
  Cannot import mp4 video in Adobe Premiere properlyBy badihi in forum EditingReplies: 0Last Post: 3rd Mar 2012, 15:42
  Can't Import Video File with AC3 Audio into Vegas 9 PlatinumBy Charlie_L in forum Newbie / General discussionsReplies: 11Last Post: 2nd Sep 2011, 08:44
  h264 problem in Sony Vegas and Ulead Video StudioBy AscAnsio in forum EditingReplies: 1Last Post: 8th Jan 2010, 09:49
  Video Quality from different encoders--Vegas, Nero, Pinnacle, Ulead, EncoreBy sir_rob in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2008, 12:32
  Premiere Pro CS3 and TMPGEnc - Can import AVI but video does not show up...By chadsxe in forum Newbie / General discussionsReplies: 4Last Post: 15th Feb 2008, 14:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
