  1. Does anybody know how to rip a DVD into a VCD but use the audio commentary.
    I use Smart Ripper and wondered if there is a way to decode the different soundtrack.
    Ta!
    May 2001
    London, UK - Bonn, Germany
    The ripping part of your DVD will be the same as the audio stream for the commentary will be in the VOB itself. Important here is that when you have your DVD in your Player try to find out which audio feed you need to hear the commentary. If your remote control has an audio button, usually you have to press it, lets say 4 times before you hear the commentary only. That would mean that the important audio layer for you is audio track 5! (audio1 is automatic +4 times you pressed the audio button = 5).
    When you are using DVD2AVI to extract the audio part for further encoding you choose track5 - that simple.
