I'm having some problems getting ffmpegx to produce an xvid avi from a dvd with a specific filesize. I've tried both the xvid mencoder and xvid ffmpeg options for the video. Some info on the video:
format - vob, ac3 audio.
length - 116min
resolution - 720x576, aspect 2.35:1
framerate - 25fps
Mencoder settings :
video:
640x272, crop 70,70,0,0
116min keep in 1400 mb, 25fps.
bitrate calculator gives = 1468 kbit/s
Qmin = 2
Qmax = 31
options = high quality, two-pass, trellis, bicubic scaling
audio :
192 kbit/s VBR, 4800, stereo.
This produces a file of size 1.12 gb, length 116min, video bitrate=1.1Mbps, audio=178kbit/s
This is 0.25gb too small! Why isn't it using the bitrate set by the bitrate calculator?
I understand the bitrate is a bit higher than needed for 'best', but I want to be able to set the bitrate and not have it change each time.
I've put the output of the i window below :
Code:Encoding started on Tue Aug 21 10:58:32 BST 2007 FIXME:Hardenabling SSE and SSE2 without detection MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team Mac OSX static build for ffmpegX CPU: Intel (Family: 6, Stepping: 6) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x5e879000 MPEG-PS file format detected. VIDEO: MPEG2 720x576 (aspect 3) 25.000 fps 7500.0 kbps (937.5 kbyte/s) [V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400 ========================================================================== Opening audio decoder: [liba52] AC3 decoding with liba52 Using SSE optimized IMDCT transform AC3: 5.1 (3f+2r+lfe) 48000 Hz 384.0 kbit/s Using MMX optimized resampler AUDIO: 48000 Hz, 2 ch, s16le, 384.0 kbit/25.00% (ratio: 48000->192000) Selected audio codec: [a52] afm: liba52 (AC3-liba52) ========================================================================== xvid: using library version 1.2.-127 (build xvid-1.2.0-dev) Opening video filter: [expand osd=1] The selected video_out device is incompatible with this codec. Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp. Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=640 h=272] Crop: 720 x 436, 0 ; 70 ========================================================================== Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES) Could not find matching colorspace - retrying with -vf scale... Opening video filter: [scale] VDecoder init failed :( Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2)) ========================================================================== MP3 audio selected VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.78:1 - prescaling to correct movie aspect. SwScaler: BILINEAR scaler, from Planar YV12 to Planar YV12 using MMX2 videocodec: XviD (640x272 fourcc=44495658 [XVID]) xvid: bitrate setting is ignored during first pass xvid: par=0/0 (vga11), displayed=640x272, sampled=640x272 xvid: 2Pass Rate Control -- 1st pass 1 duplicate frame(s)! Writing header... ODML: vprp aspect is 16384:6963. Writing header... ODML: vprp aspect is 16384:6963. Writing header... 1 duplicate frame(s)! ODML: vprp aspect is 16384:6963. Skipping frame! Skipping frame! Flushing video frames Writing index... Writing header... ODML: vprp aspect is 16384:6963. Video stream: 1312.542 kbit/s (164067 B/s) size: 1142627265 bytes 6964.360 secs 174111 frames Audio stream: 177.979 kbit/s (22247 B/s) size: 154930080 bytes 6963.960 secs MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team FIXME:Hardenabling SSE and SSE2 without detection Mac OSX static build for ffmpegX CPU: Intel (Family: 6, Stepping: 6) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x5e879000 MPEG-PS file format detected. Using SSE optimized IMDCT transform VIDEO: MPEG2 720x576 (aspect 3) 25.000 fps 7500.0 kbps (937.5 kbyte/s) [V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400 ========================================================================== Opening audio decoder: [liba52] AC3 decoding with liba52 AC3: 5.1 (3f+2r+lfe) 48000 Hz 384.0 kbit/s AUDIO: 48000 Hz, 2 ch, s16le, 384.0 kbit/25.00% (ratio: 48000->192000) Selected audio codec: [a52] afm: liba52 (AC3-liba52) Using MMX optimized resampler ============== xvid: using library version 1.2.-127 (build xvid-1.2.0-dev) The selected video_out device is incompatible with this codec. Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp. Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=640 h=272] Crop: 720 x 436, 0 ; 70 ========================================================================== Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES) Could not find matching colorspace - retrying with -vf scale... MP3 audio selected VDecoder init failed :( Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2)) ========================================================================== VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.78:1 - prescaling to correct movie aspect. SwScaler: BILINEAR scaler, from Planar YV12 to Planar YV12 using MMX2 videocodec: XviD (640x272 fourcc=44495658 [XVID]) xvid: par=0/0 (vga11), displayed=640x272, sampled=640x272 xvid: 2Pass Rate Control -- 2nd pass -- bitrate=1468kbit/s 1 duplicate frame(s)! Writing header... ODML: vprp aspect is 16384:6963. Writing header... ODML: vprp aspect is 16384:6963. Writing header... ODML: vprp aspect is 16384:6963. 1 duplicate frame(s)! Skipping frame! Skipping frame! Flushing video frames Writing index... Writing header... ODML: vprp aspect is 16384:6963. Video stream: 1186.340 kbit/s (148292 B/s) size: 1032762513 bytes 6964.360 secs 174111 frames Audio stream: 177.979 kbit/s (22247 B/s) size: 154930080 bytes 6963.960 secs Encoding completed on Tue Aug 21 13:17:08 BST 2007
	too complicated for you guys?
 nevermind, i've had to resort to using gordian knot via parallels, took a little longer but at least the output was the same as the settings...
	For more control on the output file size, use the "DivX mencoder" preset, which allows for 3-pass encoding for bitrate control to match the desired file size.
  SOS! I have output file from convert by mencoder but i don't know conmandBy zerround in forum Video ConversionReplies: 0Last Post: 24th Feb 2012, 02:38
  mkv output file audio bitrate is much higher than what I set it to convertBy Shadotaku in forum Video ConversionReplies: 0Last Post: 12th Sep 2011, 14:55
  Lower output file size from VegasBy Squid_uk in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2010, 15:28
  Using mutiple passes with lower bitrate vs single pass with high bitrate onBy jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17
  Lower video encoding tips for small 7 inch screenBy hauns in forum EditingReplies: 5Last Post: 9th May 2007, 14:54
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
