    Jun 2007
    Hi there. I've got a DVD that's been spilt to fit onto 2 DVD5s, is there a way I can re-join them back to a DVD9 keeping all the menus in tacked?
    Any help is appreciated.
    Regards P.M.G
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    It depends on how (what software) it was split. Generally speaking it should be able to be done though.
    You'll probably need something like PGCEdit or DVDRemake to modify the menus to point to the right areas.
    If in doubt, Google it.
    Dec 2006
    Here,where do you think?
    Try with DVDFab Platinum's merge mode..or this,
    http://web.archive.org/web/20060515075320/www.ifoedit.com/joinclip.html
    kind of an old guide though....
    " Who needs Google, my wife knows everything"
