Results 1 to 9 of 9
  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi All,
    I have been reading the RMBV conversion guide and it calls for the installation of real alternative codec. Since, having real alternative codec and real player in the same PC might be a problem. I would like to know if having Real Player and Avisynth together with TMPGEnc is enough for me to convert RMBV to MPEG2 ?
    Just want a confirmation before I plunge in.
    Thanks in advance.
    Apr 2004
    Miskatonic U
    I raised similar concerns some time back and was told that they can co-exist.
    Read my blog here.
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    guns1inger, thanks.
    Jan 2003
    India
    Installing real media splitter and having real player will work just as well. It is the method approved by Real. As per Real, Real Alternative does not have their clearance and is warez- a stand endorsed by doom9 forum.
  5. Member pchan's Avatar
    Mar 2003
    Singapore
    I installed the real media splitter and it works for 29.97fps but not 15fps.
  6. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi All,
    I would to give this a last shot. Using AVICodec, the rmvb file is 15 fps and 352 x 288. I am using VirtualDubMod defualt template:
    #ASYNTHER DirectShow_NTSC
    [DirectShowSource("%f", fps=15, convertfps=true)]
    But it didn't work when I tried opening the rmvb file from VirtualDubMod. The Blade2 movie trailer sample works fine.
    Thanks in advance for your tips.
    Apr 2004
    Miskatonic U
    Which version of avisynth are you using ? If you are using 2.5.7, try updating to 2.5.8 alpha. It resolves some issues with DirectShowSource.
    Read my blog here.
    Jan 2003
    India
    maybe you need to install the helix codecs
  9. Member pchan's Avatar
    Mar 2003
    Singapore
    Indeed, I am using 2.5.7. Will uninstall it and reinstall with 2.5.8.
