My friend has given me some videos he has recorded with his Canon PowerShot S3 IS. He wants to play them on his DivX DVD player. How to go about converting the videos to DivX AVI ? I have a posted a GSpot screenshot. Any help appreciated.
Results 1 to 14 of 14
No, it's MJPEG avi. Common codec for video shot with digital still cameras. ffdshow can decode mjpg, and with mp4cam2avi, you can convert your AVI to XviD AVI with mp3 audio (source audio is uncompressed) that should play on most DivX capable players.
/Mats -
I tried mp4cam2avi but cannot make it work. I cannot find any option to select the output file as DivX or XviD. Any help appreciated. SUPER is still in the state of download. Will try that soon.
From the documentation:
I've highlighted the important parts in bold.Right pane (target file/directory, conversion settings)
action
Select what you want to do:
a) Many -> Many AVI (just convert files, each source clip to separate avi)
b) Many -> One AVI (convert and join all source clips to one avi)
video format
Only available in Expert mode
By default, video is not recompressed (Source video), this is much faster and causes no video quality loss.
If you want to recompress video to XviD MPEG-4 ASP, select one of the 'XviD MPEG-4' options. If source video is MPEG-4, you shold check 'enable MPEG-4 recompression' in advanced settings to perform operation. If you are familiar to XviD settings, you can select 'XviD MPEG-4 ASP (user-configurable)' and configure codec n advanced options.
Video recompression is supported only for MJPEG and MPEG-4 ASP source video.
/Mats -
It worked. Thanks to mats for the details. One more question, My friend has the Phillips DVP 642 which plays DivX. Will the final video which is XviD work on this player?
Probably. Most DivX players also play XviD. The tool AviReComp uses XviD to recompress incompatible AVIs into standalone player friendly format, so the chances are very good.
/Mats -
To playback Divx on the DVP-642, you must NOT use:
1) GMC
2) QPel (quater pixel)
3) Packed bitstream
4) Video bit rates higher than 2000 Kbps
5) Resolutions greater than 720x576
I don't use Super for encoding to Divx, so I can only tell you to avoid these things if you want the file to play without problems. -
My output videos have a bit rate of just over 2000 kbps (2054). Will they work?
There's no fixed max allowed bitrate here. It's 100% player dependant. You simply wont know until you've tried.
/Mats
wmp win7 not playing certain mpeg1 files, gspot info included
By Rudyard in forum Software PlayingReplies: 6Last Post: 7th Jan 2011, 02:53 -
Can't hear audio on PS3 from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2010, 14:49 -
PS3 won't play audio from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2010, 19:16 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 05:19 -
Corrupt Codec? Screenshot included!
By sunny112 in forum Newbie / General discussionsReplies: 7Last Post: 10th May 2009, 09:38
