i have captured a few videos in mpeg 1 22mbps and created a VCD using Nero burning at 24x. I notice during playback that sometimes the audio/video skips. no problem playing back on my pc.
what can i do to fix this problem? slow the burn speed?
how can i enable DMA if that option is not listed when i go to control panel?
DMA settings is easy: go to "my computer" ----> control panel ----> system....select the device manager tab, select the cd-rom drive, right-click properties, click the settings tab and check or uncheck dma. restart and all should be well :) As for burning, well I have a very old 2x burner but I have read many posts about problems burning at higher speeds. What you first want to check is if your cd-r actually supports 24x burning. If it does try to burn at 8x and see if that fixes it.
I can enable DMA on the CDROM's but there is not DMA option under settings for the drive.
question: what is the sync data transfer and disconnect options? i these were checked so i checked them as well on my cd burner - is that ok? -
I think those only apply to scsi devices......you know windows does have a help function!!! rightclicking on any of those would give you a "what is this?" thingie :)
Title skip in MultiAVCHD
By maniachiavelli in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jun 2012, 22:29 -
Commercial Skip
By Montani304 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2011, 08:54 -
How to skip unselecting pictures?
By coody in forum ComputerReplies: 1Last Post: 9th Mar 2009, 11:08 -
MKV-Skip Scenes
By jah711 in forum Blu-ray RippingReplies: 0Last Post: 5th Aug 2008, 19:10 -
DVD RIP, Audio and Video Skip/Lag
By Blue_3 in forum DVD RippingReplies: 4Last Post: 8th Apr 2008, 08:34
