I have a Memorex 16x-ddl-in DVD Dual Layer burner. I am using Nero 7 Ultra. I just bought some Matrix 2.4X DVD+R DLs to try on it. Nero says there is no disk in the drive (there is). Is there something I need to change on my software, hardware?
Results 1 to 10 of 10
Verbatim is regarded as the only reliable DL media, but maybe a firmware update for your burner can cure your problem.
/Mats -
1) Use ONLY Verbatim DVD+R DL discs. If you deviate from this at all (different brand or DVD-R DL discs) you are asking for problems.
2) I'd strongly advise using ImgBurn to burn DVD+R DL discs. It works a lot more reliably than Nero.
3) I don't recommend this at all, but if you must use Nero, you might try to install the latest upgrade. That sometimes fixes this kind of problem. But that still doesn't address the fact that your Matrix discs are crap and we don't advise using them. -
OK, I only bought them cause that's all I could afford, they are ridiculously expensive. I researched them (not here) before I bought them and found favorable reviews. But even if they are crap, I don't see why nero would not even see them in my drive...
I DL Imageburn and it does see my disc in the drive. No I gotta figure out how to use it. I don't want it for ripping, I need to be able to write my VIDEO_TS after I create it (so I can start making some coasters!). -
Originally Posted by Madwand1
ImgBurn will probably ask about Layer Breaks - info and a Guide here:
http://forum.imgburn.com/index.php?showtopic=4643
[Edit: Also, with those discs, I'd *definitely* run a "Verify" after the burn - just check the "Verify" box as shown at the end of the Guide.]
Happy burning.
Jim -
Thanks. I got the problem with Nero not seeing the disc resolved...It was an I?O error, which cleared up upon rebooting. Had that before, but I can never remember when it happens.
So far, burned 4 movies with no problems, just takes a lot longer for two sides at 2.4 speed. -
I get the same No Disc error with a Memorex 16X DL Writer using Memorex DL discs OR Verbatim (+ Nero 7) so I think it's the writer that's a dud.
After trying to burn a DL disc it won't even recognise a DVD-RW with data on it (my other drive has no problems with the DVD-RW). The only thing that it sees are CD's. -
If it only sees CDs, the DVD laser is dead.
Originally Posted by trendleheap
Rule of thumb with DL burning is to only use VERBATIM which has already been mentioned.
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 08:40 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Jul 2007, 23:40
