I converted two .avi files from the same source to MPEG-2, integrating an .srt file (also from the same source) with each. When I play the VIDEO-TS file in DVD Player, the subtitles show up, but the video itself doesn't play--there's only a black screen. The audio works. The avi files do play in mplayer, with the subtitles. Does anyone know what happened? Thanks.
It recognizes the source as an .avi with the following video properties: msmpeg4, yuv420p, 640x352Originally Posted by Case
Mpeg2enc.Which DVD preset did you select? The mpeg2enc one of the ffmpeg one?
Quicktime.Which decoder was selected in the Options tab? QuickTime/mplayer/ffmpeg?
QuickTime (without Perian) might have some problems decoding msmpeg4. Try again using decoding with mplayer or ffmpeg (=quicktime and mplayer de-selected), or install the Perian QuickTime component.Originally Posted by Kagredon
How to change the color of converted subtitles with Txt2Vobsub
By uher in forum SubtitleReplies: 5Last Post: 27th Mar 2015, 11:00 -
mkv2vob: VOB converted video plays at ~5x speed
By shiroi in forum Video ConversionReplies: 1Last Post: 9th Sep 2012, 01:59 -
Recorder FLV converted to MP4 plays no video in QuickTime
By ballenato in forum Video ConversionReplies: 6Last Post: 25th Nov 2011, 10:17 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 20:06 -
random subtitles missing after remuxing converted PAL-to-Ntsc
By spiritgumm in forum SubtitleReplies: 5Last Post: 19th Jan 2009, 12:56
