Hi there,
I'm looking for a list of that will tell me which HD format (720p or 1080i) TV networks use (for both US and Canadian channels).
Also, if a TV network uses 1080i and I leave my resolution to 720p or vice-versa, what are the consequences?
Thank you
				Results 1 to 11 of 11
	If you are using a tuner in a digital TV, it will self adjust to any of the 18 ATSC formats. If you are using a cable or sat tuner, you usually set the interface connection to 720p or 1080i and the box does all the conversions.Originally Posted by the_importer
 North American networks today are either all 1080i or all 720p. In the future this may change program to program. The current 720p networks are ABC, FOX and ESPN. The rest are 1080i. I haven't heard what the Canadian networks plan to do. Sports/Animation focused networks tend to 720p.
 Some satellite and next generation cable systems will be adding MPeg4 channels in HD and SD. Current TV sets won't be able to tune these directly.
 Hope that helps.
 http://www.hdtvprimer.com/ISSUES/what_is_ATSC.html
 http://www.digitalhome.ca/hdtv/idx/0/426/article/Canadian_OTA_HD_Channel_Lineup.html
	Originally Posted by edDV
 I do have a cable box. Now if I were to leave my resolution at 720p and watch NBC which would run at 1080i, what are the consequences? I am missing anything?
 Man, these resolution wars are a PITA for consumers. It's not like buying different game systems because of exclusive titles. HD-DVD Vs BlueRay, 720p Vs 1080i, in the end, it's for the same thing with minor differences. I wish industries would settle on a standard
	In your case, try 1080i and 720p with your TV and use which is better in your eyes. The cable box will convert 1080i to 720p and visa versa. Most stations will be 480i or 1080i native. If you connect 1080i, it puts the processing load on your TV to deinterlace and downsize 1920x1080i to 1366x768p. If you choose 720p, the conversion is done in the cable box. The HDTV would then upscale 1280x720p to 1366x768p.Originally Posted by the_importer
 HD/BD store bought DVDs will be 1920x1080p native. your TV would accept 1080p, 1080i or 720p from these players only over HDMI. For a 32" LCD-TV, HD/BD won't show much advantage.
	I don't know what the situation in Canada is, but barring another extension (always possible), in early Feb. 2009 the USA will switch to all digital TV. There will be no more analog TV. Do note that the HD standard used in North America does allow for 480i/p broadcasting and I suspect that a lot of channels are not going to bother converting to 720p or better, at least in the USA. Your situation in Canada may be completely different.
 At the time the ATSC standard was proposed, it was considered more or less impossible to broadcast 1080p, so that's why 720p and 1080i both became choices. Each TV station could decide if they preferred higher resolution but interlaced frames or lower resolution but progressive frames.
	Originally Posted by jman98
 I don't quite follow you with this. Are you saying that some channels will disappear when everything goes HD because they don't want to convert to HD?
	the_importer,
 Now there's the rub. Stations are required to go digital, not necessarily high def. That is, stations will send a digital signal, versus analog, but the ATSC definition says that digital signal can be many variations of resolution 480i/p, 720i/p, 1080i/p and some in between.Have a good one,
 neomaine
 NEW! VideoHelp.com F@H team 166011!
 http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
 Folding@Home FAQ and download: http://folding.stanford.edu/
	No. I'm saying that after Feb. something 2009, here in the USA everything will go digital. That is NOT the same as saying everything will "go HD". Some channels will choose to not convert to HD format and will broadcast at 480i or 480p. People look at digital TV as being all in HD, but in fact as neomaine said, the standard allows for non-HD resolution broadcasts. 480i/p is NOT considered to be HD. Many people incorrectly assume that everything will "go HD" as you say, but that is not correct. Everything will "go digital" and individual channels may or may not be in HD at that time.Originally Posted by the_importer
	If you stay on cable, none of this Feb '09 change will affect you. The cable company will just tune to the digital version of the station if they haven't already. Canadian stations may remain analog in the smaller cities for some years.
 Someday they will offer a new cable box that tunes MPeg4 as well as MPeg2. That will allow them to either double the number of SD channels or offer more HD services.
  Question about 720p HDTV networksBy jd594 in forum DVB / IPTVReplies: 3Last Post: 8th Sep 2010, 07:50
  Books on Video Server NetworksBy m4Rio in forum Off topicReplies: 0Last Post: 12th Aug 2010, 09:42
  Seeking State-By-State List of DTV Stations with Sub-ChannelsBy Frank-0-Video in forum DVB / IPTVReplies: 2Last Post: 2nd Feb 2009, 18:07
  A Dead Format Tops Sales ListBy cracula in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Mar 2008, 00:40
  Question About Networks Switching to HDBy kerrex_2006 in forum DVB / IPTVReplies: 4Last Post: 20th Jul 2007, 17:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
