I have a Telefunken VCR that i'm using to capture video through my Hauppauge WINTV card (BT878 chipset). I seem to be able to capture video ok but whenever i fast forward on my VCR (with picture) Virtual Dub or any other capture application freezes after a while and i cannot even kill the actual process. It doesn't help opening a 2nd VDub or anything else as it seems like it's the driver or something that has crashed. This is very annoying as i need to preview everything at normal play-speed before capture to not risk the application (or driver?) crashing.
It doesn't seem to matter what compression codec i choose.
I'm using the btwincap drivers.
Could anyone help me with this problem? Thanks in advance!
So, am I to understand that you are capturing with VirtualDub?
If you are, you might want to try the software that came with your Hauppauge unit - it should be WinTV2000. That should fix you up. -
Welcome RedFarmer
dadrab's advice is correct .
However , if you want to keep using vdub ... you should set multi segment capture , and set "name increment" .
Setup vdub , start recording , and leave it till entire tape has completely played back .
Slice and dice using vdubs append feature later .
Fast forwarding cause's the device to loose track of input signal ... bad idea when considering the use of btwincap drivers ... its just bad practice in general .
Either do it as mentioned , or shutdown vdub to release the capture device , fast forward to next part , reset vdub's capture to new avi to proceed with next capture .
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 19:42 -
Capture Freezes on all programs
By Justinpd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Oct 2008, 17:05 -
Pressing Capture Button Freezes Program
By Mengsk in forum Capturing and VCRReplies: 13Last Post: 5th Jun 2008, 16:45
