Tmpgenc will not encode one of my avi's to vcd standard. It seems to be something wrong with the audio, If I change the audio to 44100 it won't work, and gives an error saying problems encoding audio. If I leave it at 48000, it will encode ok. Wil my stand alone dvd player play the sound ok if I trun the vcd compliance off?
Also, I can not work out how you load the VCD template-I have read iser guides, but cannot find it-can anyone help. Also should I use PAL settings if I am in the UK?
Thanks all.
I would seriously try to demux the avi, and resample the audio to 44100. Then TMPGEnc should encode it fine (HINT: make it a 44,100 WAV file, makes direct conversion easier)
Just use the separate video/audio sources for your input streams.
Nero - Compliance test failed? whats up w/ this?
By BRYAN_B28 in forum Authoring (DVD)Replies: 11Last Post: 2nd May 2012, 02:13 -
Mpeg2 Compliance and DVD Autoring.
By sambat in forum Authoring (DVD)Replies: 4Last Post: 22nd Apr 2012, 08:50 -
How to verify burned Music CD is compliance to all CD players ?
By SingSing in forum AudioReplies: 9Last Post: 26th Sep 2010, 20:28 -
Easily check DXVA compliance?
By Quasit in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 12:21 -
DVDReMakePro - Nero compliance error?
By Sephiroth666 in forum DVD RippingReplies: 7Last Post: 1st Dec 2007, 10:15
