I'm stuck at a strange point, I cannot run the already installed program, nor can I uninstall it. I can't install over it.
Every time i try to uninstall using the add/remove programs, i get an error stating the installed product does not match the installation source. It asks for me to point it to SVCD2DVDv2.5.msi, but it doesn't like the one i have, or the one i just downloaded. it says the file c:\etc....SVCD2DVDv2.5.msi is not a valid installation package for the product SVCD2DVD 2.5
So what do I do? I'm stuck.
I've tried:
deleting all the files in the directory where it was installed, then running uninstaller again.
restored those files to try again a different way.
Are you still having this issue?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Maybe this will help to get it uninstalled:
https://forum.videohelp.com/topic316353.html?highlight=removeSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
WinXP SP3 Problems
By bevills1 in forum ComputerReplies: 5Last Post: 1st Aug 2010, 22:48 -
System.UnauthorizedAccessException error after WinXP SP3 install
By scoop46 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Oct 2008, 09:03 -
anyone else install winXP sp3 yet?
By aedipuss in forum ComputerReplies: 5Last Post: 25th Apr 2008, 11:01 -
computer freezes, won't allow WinXP install
By iThinkYouBrokeIt in forum ComputerReplies: 15Last Post: 13th Aug 2007, 18:07 -
Two problems with WinXP re-install
By tweedledee in forum ComputerReplies: 9Last Post: 23rd Jun 2007, 20:38
