Hi, is there anyway to password protect a folder in a way that allows you to view it without having to extract it other than zip?
Tim
sure if you want to buy software to do the job.
http://www.y0ys.com/hide-folder/overview.htm--
Cryptainer LE is free software to create an encrypted 'virtual drive'..
http://www.cypherix.com/cryptainer_le_download_center.htmI am just a worthless liar,
I am just an imbecil -
How are your accounts set up on your computer? i.e., do you have your own, password-protected account and do other users have their own accounts?Originally Posted by dimtim
If so, simply ensure that only your account has access to the folder (via the security settings for the folder). Anyone else who logs into their account will not be able to access the folder - unless they have admin rights. So, if the computer is administered by someone else, they'll be able to access it.
If, however, you have a shared account on the computer (i.e., no password set for it) and it isn't an admin account, then an admin (via the admin account) can configure the folder's security settings to allow only you to access the folder. As before, if there is a separate admin account that isn't yours, the admin will be able to access the folder.
If neither of the above work, you'll need a third party solution as suggested by TooLFooL, AlanHK and aedipuss.John Miller
LG RC278 (RC-278) DVD-RW/VCR Hack Options - Copy Protection question
By vicctor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Sep 2013, 16:31 -
Lost Password
By HotDamn! in forum ComputerReplies: 5Last Post: 8th Jun 2010, 22:15 -
Making password!!!
By Seasonal in forum ComputerReplies: 3Last Post: 21st Nov 2007, 18:10 -
Boot Up Password
By SIRCOOKS in forum ComputerReplies: 6Last Post: 21st Oct 2007, 22:04 -
Help with password.
By tweedledee in forum Off topicReplies: 4Last Post: 25th Aug 2007, 04:52
