my vcr used to be able to play back recorded tapes but now it won't play them i tried a store bought tape and it worked fine so why won't it playback the other tapes?
What does it do when you try to play one back? Were they recorded on the same machine? Have you tried to adjust the 'tracking'? On some VCRs you can use the channel 'up<>down' buttons during playback to adjust tracking if there is no separate tracking adjustment.
a scrambled screen comes up no picture no audio but i've watched these tapes before on this vcr and they played fine i also tried tapes that weren't recorded using this vcr and they still don't work. and the vcr doesn't come with a tracking button i tried the channel up/down buttons and nothing changed.
I hate to suggest it but maybe they have been erased by being too close to a strong magnet...even without you knowing.
Can you try them on another deck?
Have all the bad ones been stored together? -
i did try playing them in the older vcr and the movies played fine its just this vcr. is there any way of fixing this?
Is there a VCR that will play VHS-C tapes without an adapter?
By moxiecat in forum RestorationReplies: 23Last Post: 25th Oct 2012, 04:24 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36 -
Where to get a PAL VCR to play Eutopean VHS Tapes?
By tezarin in forum Newbie / General discussionsReplies: 8Last Post: 11th Jul 2008, 16:48 -
sony hvrz1p wont play last 10mins of tapes
By jjthejambles in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Jul 2007, 04:12 -
¿How to make VHS-C tapes play well on AG-1980 VCR?
By CCEncoder in forum Capturing and VCRReplies: 0Last Post: 20th May 2007, 08:23
