Hellow everyone i am a newbie here..... well here is my question....
I downloaded a movie from DEMONOID ...i used UTORRENT to RIP IT..... then i converted it ...i used convertXto DVD...then i burned it also using convertXtoDVD...when i played it on my DVDPLYER the sound was waay toooooo LOW!!!....so i am trying to make that copy of the movie whith a LOUDER VOLUME....PLEASEEEEEEEEEEEEEEEEEEEEE can someone help me with baby steps i am not GREAT with computers like all of you guys in here!!!![]()
when i copyed the movie to my hard drive..and i open the movie file it has VOB. files and IFO.FILE.
THAKSSSS
Results 1 to 10 of 10
What kind of file was the original download?
My guess is that it was some sort of AVI file probably in DivX or XviD format.
Open the file up using GSpot and do a screen grab and post it here.
Will be much easier to go back to the source ... correct the audio ... then feed it to ConvertXtoDVD for a new conversion.
- John "FulciLives" Coleman
P.S.
Here is a link to a guide that explains how to do a screen grab and then post it here:
https://forum.videohelp.com/topic271697.html"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
OH OH OH!!! sorry i forgot to put this in...the original movie file was an AVI. FILE...i looked up the movie i downloaded to find out for ya
KITCAT12 8) -
ConvertXtoDVD can increase the volume when it encodes. Just go to the Audio tab under Preferences/Settings.
Read my blog here.
Well there you go ... just feed the original downloaded AVI file into ConvertXtoDVD and do what guns1inger said to do.Originally Posted by guns1inger
I didn't realize ConvertXtoDVD had that feature.
I admit I have it and use it from time to time but not very often ... only when I am "lazy" and have a ton of files to convert (like a bunch of TV episodes).
YES i tryed already it is on the highest volume set. Does anyone else know how to make my movies louder???? Remember there are a lot of people out there that donot know how to upload a movie correctly..like fixin the VOLUME CORRECTLY before they up-load a movie....soooooooooooooooooooooo intern people like me and you who love to download movies...get STUCK with shity volume..that we INTERN HAVE TO FIX.
PLEASE someone HELP me ...i know it should NOT be that HARD to fix this tiny problem..
I do have AC3filter on my computer....
funny yesterday i downloaded a movie and before i converted it i played it on my MEDIA PLAYER CLASSIC...then i opened up the AC3Filter..i fix and adjusted the VOLUME, and click
the APPLY button...then i converted the movie on my convertXto DVD ...then i burned it...then i put it in my SONY DVD PLAYER ....and can you believe that it said it could NOT READ DISK!!!....sooooooooooo i put the dvd in my computer to check it out...and to my surprise the movie DID NOT EVEN BURN ON THE DVD!!!!!!!!! That really FREACK me out BIG TIME>>>
I have tryed everything ....STUMPED....HELP!!!!!!!!!!!!!!!
KITCAT12 -
You can demux aka demultiplex the audio from the original video file. That means you extract the audio to an audio only file.
Then you can manipulate the audio and in this case you probably want to normalize the audio to the 0.0db reference level.
There are multiple ways to do this and no one way is necessarily better than the next ... it mostly depends on what kind of file you have and what kind of audio you have to work with i.e., the formats or codecs etc.
Do you still have the AVI file that you downloaded? If so then we can continue ... after you post an image of the file loaded into GSpot.
I already mentioned this once and had you done it when I first asked we still wouldn't be here. So just do it already.
Refer to my first post in this thread for a link that describes how to snap a screen shot of GSpot and then how to post it here. That guide tells you all you really need to know to get that much done.
Can you increase volume of ADPCM sound in movie?
By johnharlin in forum AudioReplies: 3Last Post: 18th Sep 2010, 17:15 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 11:43 -
i need alot of help converting .avi to dvd?
By just in forum Newbie / General discussionsReplies: 17Last Post: 21st Oct 2008, 15:51 -
some1 with alot of xperience plz help,regarding avi to dvd?
By just in forum Newbie / General discussionsReplies: 3Last Post: 16th Oct 2008, 23:42 -
adjust or normalize volume ac3 5.1 sound of a movie
By volam in forum EditingReplies: 18Last Post: 16th Nov 2007, 14:32
