    Jun 2007
    I 've been trying to convert a RM file to a movie.m2v for 2 days,still no luck ! Is there a easy way of doing this ? The reason I am trying to do this is this RM file has 1 or more audio track,which I am not sure of . When I playback this file with Creative Zen Vision M,each side of the earset has one different chinese diaglogue ! My main concern is the audio editing ! Any help would be appreciated ! Thank-you Very Much !
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    What tools are you using? There should be an audio option in the tool that allows you to choose which audio track you want. If not, you may have to demux the audio track(s) first. Then remux the audio with the video after conversion.
    Google is your Friend
