I really enjoy the Divx Ultra Projects that I make with TDA 3. I have a question though, do you think this format is going to catch on or will it be quite likely that in the future I won't be able to buy a Divx Ultra Player to play my discs?
I have hopes that someone at Videolan is going to add the capability to play this format with their software player. I am not very anxious to install the Divx Software Player after reading through their EULA that comes up before you install it.
I really think TDA 3 is a really neat program. I couldn't ask for a better DVD Authoring Program, because of the ease of use and the features included within the program.
I kind of suspect that other than the menus there isn't much going for Divx Ultra. Making a Data Disc is alot quicker than the 5 and half hours that it takes to make a Divx Ultra Project.
I posted a suggestion over in the VLC Suggestions Forum about Divx Ultra Support and a developer expressed interest in it.
It seems like I should get an encoder to convert my mpeg2 files to XVid format and then just put those files on a Data Disc.
Maybe sometime down the line there will be high capacity discs that one can put mpeg2 files on and not have to convert them and be able to make conventional DVD Projects.
Thanks jagabo for your input.
Divx Ultra .divx files on philips DVP5140
By marioval in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Nov 2009, 11:45 -
ffmpegX 0.0.9y & future?
By Flarch in forum ffmpegX general discussionReplies: 12Last Post: 11th Apr 2009, 17:56 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Using x264 to encode DV to AVC for archiving & future authoring to HD-D
By miamicanes in forum Video ConversionReplies: 0Last Post: 11th Sep 2007, 11:10
