hello,
The DVD's normally would buy from the store how do i make them professional DVD's on my own system using like TMPGEnc to convert them from AVI and i believe the store DVD's are copyright? Is there any guides to make them professional like that?
Results 1 to 21 of 21
If you want same copy protection as on commercial dvds you can burn them yourself. If you want good looking menus it's just lots of work, see for example https://forum.videohelp.com/topic331892.html?highlight=professional%20dvd
I didn't see on that topic how to make the menus. how do i burn compyright?Originally Posted by sedtedgmail
Ooops, I mean If you want same copy protection as on commercial dvds you can NOT burn them yourself.
ok. how do i make the menus and settings the same way as commercial DVD's? I will be using TMPGEnc Plus for encoding.Originally Posted by sedtedgmail
You need an authoring tool -- to combine the MPEG, audio, and make menus, and produce a VIDEO_TS folder ready to burn..Originally Posted by php111
See https://www.videohelp.com/tools/sections/authoring-dvd
I personally use GuiForDVDAuthor.
Whatever you choose, you will have to spend some time reading the documentation. -
Begin with a simple, foolproof authoring tool like TMPGEnc DVD Author then work your way up to more complex tools after you have gained more experience. Eventually, you will be able to make "professional looking" DVD's but this is not the same thing as a commercial disc.
As has been pointed out in many posts before, professional looking DVDs can't be created from guides or because you have a particular piece of software. Professional looking DVDs come form planning, preparation of assets, have a good eye for design, being able to use still image software, editing and/or effects software, and understanding how to make the navigation feel right. The authoring software is only used to glue everything together at the end. It is everything you do before you author that makes a DVD look professional.
Read my blog here.
OK. how can i do all of that so it can be a commercial DVD on my system?
There isn't any home authoring software you can use to make a commercial DVD. For a start they are pressed on giant machines and not burnt in a PC drive. The plants which press them require digital masters which are made to exacting standards. You would need about $50,000 worth of software and several years programing experience to be able to meet those standards. It is far cheaper/easier to hire a professional authoring house to do the work for you.
Well said. There are those who expect magic and instant gratification from an authoring program. But it really is just the canvas upon which a competent designer applies the "paint".Originally Posted by guns1inger
Yes. Authoring tools. That's what you need.Originally Posted by php111
TMPGEnc makes MPEGs.
You use them in an authoring program, as those linked.
You keep using the words "professional" and "commercial".
I don't know what you mean by that.
Just what do you intend to do with your discs?
For what it's worth, I think my discs are professional in that they work and aren't too ugly on the screen. But they're obviously not commercial because they don't have a lot of crap to click through like most "commercial" discs force you to before they let you see the damn feature. -
hi,Originally Posted by AlanHK
I just plan on watching the DVD's on a DVD player. What would be the best way to setup TMPGEnc settings to encode to an MPEG Alan? Up above saying i can't make commercial at home. What i mean by commercial is burn the DVD's the same way they are encoded and authored like they are at stores. -
There is nothing you can buy which will make professional looking DVDs instantly. You need to begin with a simple but foolproof authoring tool, practice a lot, get things looking as good as you possibly can, then move on to a more elaborate authoring tool. After about three years you will be able to author discs with fancy interactive menus which look like they've been bought from a shop. Learn to walk before you can run. I strongly recommend TMPGEnc DVD Author as you are using their MPEG encoder already. It is foolproof, easy to learn and (with a bit of practice) can make some pretty decent looking menus. It has some limitations but by the time you have learnt what they are you will be ready to move on to a more elaborate authoring tool.
Hi, I just bought a pair of running shoes at K-Mart and I'm going to compete in the 100 meter race at the 2008 Olympics. Should I thank everyone before they give me the 1st place trophy or wait until they hand it to me? I just want to be a "professional" winner.
Capice? -
If you're just going to watch them yourself, or give to friends, all you want or need is to make standard DVDs with simple menus (or no menu, if you only have one feature). You don't want to be "commercial" at all, and professional only in the sense that you follow standards.Originally Posted by php111
There are plenty of guides here as to how to do that.
See https://www.videohelp.com/tools/TMPGEnc
A whole page of links to articles about how to do it.
I don't use TMPGEnc myself, but plenty do so if you have any problems just ask and someone will help. -
Professional looking DVD's aren't made from avi's so your starting point is already going down the wrong track.Originally Posted by php111"Art is making something out of nothing and selling it." - Frank Zappa
Alan on that page all i seen is TMPGEnc to download which i have and different formats converting nothing about menus and chapters.Originally Posted by AlanHK
Page down. There are dozens of articles linked.Originally Posted by php111
- Guides for this tools:
How to convert DivX/XviD with AC3 to a DVD with AC3 and subtitles
Add permanent subtitles to VCD,SVCD,DVD,AVI with ffdshow or vobsub and convert with Tmpgenc
Audio Compilations on DVD Guide
AVI to DVD MPEG (using CCE or TMPGenc encoders)
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD(AVI2DVD)
Basic and Advanced TMPGEnc and TMPGenc Xpress guides
Best Way To Convert a 320x240 Low Bitrate DivX to VCD
CDDA on DVD, aka creating "Audio DVD-Video"
Configuring TMPGEnc for high-quality, DVD-compliant MPEG-2
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
Converting SVCD PAL 25fps to SVCD NTSC 23.976fps
Create a still picture VideoCD with sound comments
Creating (S)VCD Stills with Audio
DivX to VCD MPEG All-In-One Guide
doom9 DV to DVD guide
doom9 DVD to SVCD using DVD2SVCD
doom9 DVD2SVCD guide
DVD to (S)VCD with Menu's and Chapters
DVD to MPG for PocketPC
DVD to one DVDR using DVD2DVD(DVD2SVCD)
Exporting your video from Premiere to TMPGenc
High Quality Capturing with Little Frame Loss in VirtualDub
How to author a working DVD containing multiple SVCD's
How to capture DV Video from your camera and convert it to DVD
How to convert a DivX file to DVD MPEG2
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
How to Convert OGM to DVD
How To Convert To Pal or NTSC With Dgpulldown
How to correct reversed field order in interlaced MPEG
How to create a pictures VideoCD with transitions and continuous background music
How to create hybrid frame-rate (aka VFR) MPEG-2 for SVCD or DVD in TMPGEnc
How to fix gradual loss of sync once and for all
How to repair a VCD or a SVCD
Joining MPEGs to AVIs, AVIs to AVIs, etc. Using Frameserving
Make Award Winning slideshows with MemoriesOnTV and TMpgEnc
Motion menus and chapters with DVD-Lab
OGM to SVCD easy Guide
Optimizing TMPGEnc for quality AND speed
Perfect AV Sync: SVCD/VCD to DVD
Play Your PC's Video Files on ReplayTV
Removing commercials from MPEG files using TMPGenc or Womble MPEG2VCR
SatStorm 's Advices: A 12 step NTSC to PAL conversion guide
Sefy's classical DVD to VCD ripping guide
Sefy's DVD Backup Guide v2.6
Standards FrameRate Conversion
Tenders SVCD Cutting Guide
The newbies guide to fitting a movie on one CD using TMPGEnc
TMPGEnc common problems and tips
TMPGEnc Explained
Using a frameserver between Premiere and TMPGEnc
VCD To DVD Conversion without reencoding the video
professional dvd authoring
By adventurer9 in forum Authoring (DVD)Replies: 10Last Post: 29th Feb 2012, 18:28 -
Buying a professional or semi-professional camcorder
By besimky in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2010, 16:21 -
Professional DVD Recorder for Aviaton Project?
By steevg in forum DVD & Blu-ray RecordersReplies: 4Last Post: 1st Jun 2008, 02:36 -
TDK Professional DVD-R media ID?
By lordsmurf in forum MediaReplies: 4Last Post: 15th Dec 2007, 11:08 -
Professional DVD menus
By Tomacco in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2007, 22:21
