Hi all,
I hope I have posted this in the right forum, if not I apologise
I have converted an AVI file to DVD, but the audio on the DVD is out of synch. I use DJRumpy's excellent guide to convert it over.
The AVI file's video and audio is in sync, so there is no problem there, its only when I get to the encoding stage that it is out. I use VirtualDub Mod to extract the audio to WAV and then convert it to AC3 using beSweet. I then use CCE to encode the AVS file and DVD Lab Pro 2 to author the created files. I have tried converting it to various formats (MP2 etc) but with the same result.
For example, the AVI that I am encoding is reported by GSpot to be 1:55:40, but the two files that are created and subsequently displayed in DVD Lab Pro 2 are :
video: 1:55:39
audio: 1:55:38
When the DVD is authored the audio is out of sync.
Are there any programs that can adjust the audio in the VOB file? and can anyone advise any possible solutions or what I might be doing wrong?
Thanks very much for your time.
Deathwalker
Hi-
No.Are there any programs that can adjust the audio in the VOB file?
You probably didn't do anything wrong. There was probably a delay in the muxed AVI you didn't know about and didn't take into account. To fix it, find out the amount of the delay and apply it when using DVDLab Pro to author, doing it all again. Or, if DVDLab Pro has no way to set a delay, then fix it for good using DelayCut on the AC3, and then reauthor.and can anyone advise any possible solutions or what I might be doing wrong?
If you'd rather not go through the entire DVDLab Pro process again, then demux using PGCDemux. Reauthor using Muxman. It can add in delays up to +/- 300ms. You can use it if the delay is within 300ms, or run the AC3 through DelayCut. Then open the out-of-synch DVD in VobBlanker and use the "Replace" button to replace the old video with the new and fixed one. -
Thanks for the quick reply Manono.
Just a quick question, how do I find the audio delay in the muxed AVI.? I have demuxed the audio and video from the VOB files using PCGDemux and that told me there was no audio delay.
Using the files created I pluged them into DVD Lab Pro and the video and audio times were right, I will try using Muxman -
Hi-
I don't know. If there's a way, perhaps someone else can tell you. What I can tell you is how to find it out from the muxed VOBs, pretty close anyway:Just a quick question, how do I find the audio delay in the muxed AVI.?
This assumes it's a constant delay - that it's the same all the way through. Open a VOB in Media Player Classic. Right-click the screen and go Options->Filter->Audio Switcher->check the "audio time shift" box, and fill in an estimate of the amount of asynch. 1000ms=1 second, and a negative delay moves the audio forward against the video. A positive delay delays the audio against the video. Hit "Apply" and test it out. Resume playback. Adjust until you get it right. At that point you'll know how much the audio is out of synch and how much to set the delay in your muxing app or in DelayCut.
When all done, either uncheck the box or set the audio time shift back to 0 in MPC.
It would, wouldn't it, as you never set one.I have demuxed the audio and video from the VOB files using PCGDemux and that told me there was no audio delay. -
thanks for all your help manono, I have it nearly right but I think that there is a time delay difference in each VOB and that it is not constant.
Cheers
deathwalker
Audio to video delay value on a DVD
By nic2k4 in forum EditingReplies: 20Last Post: 7th Dec 2011, 04:06 -
where is the audio delay time stored on an authored dvd?
By Toastie in forum Authoring (DVD)Replies: 1Last Post: 12th Oct 2009, 08:45 -
How to change highlight delay in authored menu?
By gsh in forum Authoring (DVD)Replies: 3Last Post: 17th Sep 2009, 11:09 -
no audio when DVD authored
By shaolin2006 in forum Authoring (DVD)Replies: 6Last Post: 31st Aug 2008, 13:39 -
Audio Delay on DVD
By JOHNTOUPS in forum AudioReplies: 0Last Post: 25th Feb 2008, 21:41
