i tried to load a svcd mpg file in tmpgenc to edit it, but it wouldn't load it up. it acted as though i didn't have the right svcd codec installed, even though i have both powerdvd and windvd installed.
why would this be happening?[/b]
so... using this M2V VFP, TMPGEnc will able to load M2V files (even though its supposed to already if you installed PowerDVD/WinDVD cause the DirectShow Filter or such would kick in...)
anyways, an alternative way is to use DVD2AVI, load the M2V file, save the project, then use TMPGEnc to open the project file.
Better method to update software already installed
By shans in forum Newbie / General discussionsReplies: 10Last Post: 27th Feb 2012, 10:07 -
any software that can be installed on an external hard-drive or USB stick?
By lee09 in forum EditingReplies: 4Last Post: 8th Sep 2011, 09:01 -
software to "load" DVD
By AlanHK in forum DVD & Blu-ray WritersReplies: 11Last Post: 17th Apr 2010, 07:07 -
Installed software ,No Discs?
By visionman in forum ComputerReplies: 5Last Post: 14th Jan 2009, 16:43 -
Can someone with TMPGEnc installed check here?
By berfles in forum ComputerReplies: 3Last Post: 4th Jul 2007, 15:11
