    Aug 2007
    my question is, is there anyway of extracting (i use DVD Decryptor) the entire DVD content into maybe one large file (not .ISO) instead of many so i can load just one file for conversion.?
    example, i'm doing a music DVD and there's 19 chapters but i don't want to do them sepreatly or convert them all then join them i'd like to do them as one XviD if this is at all possible please direct me to a guide if there is one, i searched but no luck, or let me know what to do and tell me if i need any certain apps for this job. Thanks.
  2. Hi-
    In DVDDecrypter, go Tools->Settings->IFO Mode->File Splitting->None. Just make sure you decrypt using IFO Mode (at the top, Mode->IFO). You can do the same thing in File Mode, but from what I understand, you want IFO Mode. You don't want to extract the menus or any extras into one big file along with the music videos, do you?
    Of course, a better way would be to extract the vobs normally, and then join up the video when making the D2V Project File in DGIndex, extracting one big audio file at the same time. But I don't guess you're using AVISynth for the job.
    Aug 2007
    Thanks manono, i will try this.
