Hello I need to hook up my Canon MiniDV camcorder to a PC to capture and edit but I'm so used to my mac hardware/software I'm not sure what to do.
Do I have to have a firewire connection or can it be USB2? I don't see firewire on the PC I'm trying to use.
Also what software would i use to capture and edit? Does Windows have an imovie-type software in the operating system?
Thanks in advance.
FireWire is what you want with most any DV camera. USB is generally for snapshots or low resolution web video.
There are quite a few programs that can transfer DV to the computer. One of the simplest ones is WinDV. Once you get the DV on the computer hard drive you can use the AVI type editor of your choice. I use VirtualDub Mod most of the time. Both VDM and WinDV are freeware. VDM needs a DV codec like the Panasonic DV Codec installed.
And Windows Movie Maker that is included on Windows XP can also do DV transfers and editing. But you would need to output as DV if you wanted to convert to a MPEG format for DVD later.
If you need a PCI FireWire card, they are usually about $20 US and are 'Plug and Play', so no configuration or drivers are needed.
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
New Mac user here
By Nilfennasion in forum MacReplies: 14Last Post: 6th Oct 2008, 23:57 -
Need Help Finding Camcorder & Software to Win Soul Mate Back
By gbooth in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2008, 14:25 -
Problem with connecting Samsung miniDV to PC thru 1394 port ?
By vu9300 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Sep 2007, 02:40 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
