Hello, I have Tempgenc 4.0 express the registered version. For the past 6 months I have used this program without any problems. All of a sudden, when I click on the icon to launch the program, nothings happens? I restarted the computer, again nothing. So, I uninstalled and then re-installe dthe program, I click on the icon...the program will not start? Why is this happening?
	Hard to say for certain. Prolly a support .DLL file is the wrong version or corrupted. Not easy to fix without seeing it. I'd run filemon.exe from sysinternals.com to see under the hood as to which file is hosing when you click on the Tmpgenc icon. I know you want someone to say "it's THIS", but you'll have to find the culprit through some trial and error.
 Here's an example of what filemon shows as I open another video encoding app
  Need help converting to MP4 with TMPGEnc ExpressBy rede96 in forum Video ConversionReplies: 0Last Post: 11th Aug 2011, 16:29
  TmpgEnc Express can't open some AVIBy pcb in forum Video ConversionReplies: 7Last Post: 29th Jul 2011, 14:28
  TmpgEnc Express can't open flvBy pcb in forum Video ConversionReplies: 9Last Post: 1st Aug 2010, 16:45
  XVID/mp3 file wont open in TMPGENc expressBy efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 17:16
  TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
